I'm a cyclist and I've heard it said that all cyclists are amateur metallurgists. For some reason, I'm guessing that all car detailers are amateur chemists ;-) — so here's my question…
I'm new at all of this and used Collinite products for the first time this weekend on silver 2013 Toyota. Great experience with 845.
In my attempt to select compatible products, I ordered 480 (pre-wax cleaner from AutoGeek). I learned, after use, that I missed AG's warning not to use with clear coats. That said, Collinite's website and product label says it is for use on lighter clear coats (silver, white) — which I DID read prior to use.
I've found threads here that hypothesize about 480 causing flaws that are less noticeable in CCs over lighter colors. I honestly did not notice any scratching, but something didn't seem quite right …
What I experienced was areas where the 480 was difficult to remove. I either had to work harder or use a little spray detailer. The finished product (post 845) does look great, but I remain curious as to what was actually happening.
I've been in touch with Collinite. They assured me that I haven't caused any damage (which I honestly was concerned about
), but recommended discontinuing use.
Does anyone know what actually happened when I applied this? Feed back please Thanks.
