DFB
- Aug 12, 2019
- 6,114
- 5,595
- Thread starter
- #141
WASH AND WAX SERIES - Continued.............................
Ethos Ceramic Shampoo – While specifically designed to work with ceramic coatings, this soap will also play with waxes and sealants. With Si02 in the formula, Ceramic Shampoo will enhance and prolong the underlying ceramic coating, while also providing sufficient cleaning ability and foam. Unlike other products here, Ethos Ceramic Shampoo has a less obvious look and feel after use, Ethos suggesting the “hydrophobic effects increase with every wash, water beading effect does not appear instantaneously upon first use.” To me, this means it contains less Si02, so don’t expect this to transform bare paint.
Of the soaps tested, this is the one I liked the most, and by a clear margin too. The fact it actually foams is a big part of that! The pleasant “cucumber-melon" scent of Ceramic Shampoo is quite subdued compared to other Ethos products. Slickness was decent too. Probably the only one of these I would buy again.
Lubrication – 8/10
Cleaning Ability – 8/10
Scent – 8/10
PH Level – 7.5 (claimed)
Consistency – Medium thickness
Overall Rating – 8/10
Koch Chemie Nano Magic – Described as a high-gloss soap with long-term sealing properties, it won’t strip previously applied waxes and sealants. Don’t go into this product expecting GSF levels of foam quality, but it does blanket the vehicle in a thin layer of soap that holds on quite nicely. Using the wash mitt and then rinsing activates that Si02 element.
In use, the soap is decently slick, but again, not to GSF levels. The scent is that very distinctive and pleasant KCx aroma. Interestingly, the pH level is acidic leaning. Nano Magic is best used as a light maintenance rather than a heavy-duty cleaning soap, just don't expect it to transform flat, un-protected paint. I've also found it to induce sheeting rather than ultra strong beading like Hydr02 Foam does.
Lubrication – 8/10
Cleaning Ability 7/10
Scent – Hard to describe
PH Level – 5.5
Consistency – Thin
Overall Rating – 7/10
Conclusions -
I've come to the realization that these soaps are not for me. While they certainly add some protection and slickness to the equation, they lack the foaming ability that I prefer and have a strange feeling underneath the wash media.
Of the soaps used for this comparison, the clear winner for me was Ethos Ceramic Shampoo, primarily because it foamed properly and felt the nicest to work with. Carpro Hydr02 Foam seemed to have the most protection potency, but was a letdown in every other way. Inspiration Radiance produced the most visible gloss and slickness improvement. Of the products that produced watery foam, Nano Magic seemed to have the most holding power.
While I can see these soaps have a purpose, they are targeted at a very specific user who just wants some beading and gloss without having to apply a ceramic coating, wax or sealant. For me, what they bring to the table does not out way their lack of foaming ability, lower cleaning potential, so-so slickness or weird scents.
Lubrication – 8/10
Scent – 8/10
Lubrication – 8/10
PH Level – 5.5
Consistency – Thin
Conclusions -
