BlueBeast14GT
- Sep 17, 2013
- 344
The Water Must Flow
I've been looking into replacing my Gilmour brass quick disconnects with something that has a bit better flow. Along the way I noticed the QDs are only part of the problem...
That is a brass shut-off valve from Home Depot, and it's juxtaposition next to the Arrested Development sticker is no accident.
The inner diameter of the ball valve is just over 1/4". That's a third of the inner diameter of the hose. Unfortunately, well... geometry.
You may think this means that the flow is reduced by two thirds, which sounds bad enough, but you're wrong. The area of the opening through which the water flows is reduced from 0.44 square inches to a measly 0.05 square inches. That's not 1/3 of the water flow, it's 1/9!
Also unfortunate is the fact that there aren't a lot of consumer options. The water pressure needed to keep your petunias alive is fairly weak compared to the pressure needed to blast bird crap off of your paint. The best option I could find was the Dramm Heavy-Duty Brass Shut-Off Valve, but even that only has a 1/2" ball opening. It's better, but screw that, this is Autogeek!
