Hi all
How often should I oil the felt ring on the 3401?
Mike Phillips recommends every time you swap out the plate.
For those who only use one plate? I'm not sure..
I was also wondering if they are replaceable.
What type of oil are you guys using?
How often should the felt ring be replaced?
I've never replaced one and instead what I do is pry the felt ring out of the housing and flip it over. Then oil it and re-install the backing plate.
I'll see if we can't get replacements on the AG store. I know a few of the 3401's in the garage could probably use a fresh felt ring.
What is the felt ring's function?
