Tato
- Nov 27, 2013
- 2,157
Hey at least you're honest!!
The 3401 is the only polisher I've ever used but I have a hard time understanding people that claim the Rupes corrects better. I mean the Flex is forced rotation. You can stand on the damn thing. IDK…. most people mention the MF pads which I have no experience with either. Why are they better? And why can't you just use them with a Flex?
MF pads sound like they don't last and sound like a pain to clean between sections.
Hi,
Gotta agree to disagree with you! By the way, I have some use on MF pads and at least the Meguiar's discs (both) and the Lake Country DA MF pads are great.
I do use them a bit differently (that may be subject to another topic), mainly brushing the pad frequently and adding more product to the pad with the brush, like re-priming the pad.
I only add product to 'semi-dry' sections of the pad, but brushes it entirely.
The trick part of MF pads is to maintain them neither wet or dry, every extreme will make it behave less than optimum and hard to clean between sections. That's why brushing with product helps a lot.
AREA for correction should be small (generally).
Polisher SPEED is also important, as MF pads 'likes' lower speeds, it means speed 4 on Meg's DA and maybe 3 on the Flex.
Lower speeds doesn't means barely rotating. As MF discs are THIN, DA polishers have plenty of power to spin them considerably fast, specially the 5" version. I would go with 6" for the Flex, but also will try the 5".
Pressure is not high, it's FIRM.
Arm speed is really SLOW.
Passes are no more than 6.
Fact is, I'm pretty sure I'll keep using MF pads on the Flex, they have their space and cut smooth through hard paint. It's just like treating them a bit differently than foam pads.
Mainly you haven't felt the need for it yet because comparing Foam with a random orbital vs Foam with forced rotation, you can already do really well with Foam pads and the Flex. Free spindle DAs are relying on MF to achieve higher degree of correction.
MF cuts great and can use virtually any existing compound and proper technique. If any haze, 3-4 passes with a WHITE polishing pad and a finer polish may refine the finish even more.
They last, and are easy to clean if you soak them and brush with proper soap till clean, letting them air dry or spinning them dry.
The MF resists much better to the pad brush and this makes it resistant and easy to clean.
Nowadays they are my 2-go for cutting, but I haven't received the LC Orange Hybrid pad + FG400 yet... !
There's a video of Mike Phillips with Meguiar's 'guys' showing MF DA system. Observing the technique applied by them was crucial for me to start enjoying MF the much I do.
Some time in the video, 'Mike P.' says: 'you've done what, 4 passes?!'. Great instructional video indeed.
Hope I've helped,
Kind Regards.
