WRAPT C5Z06
- Nov 12, 2009
- 12,615
- Thread starter
- #21
I agree.id like to say the Mille, but i'm sure it'll be very negligible between Rupes and Makita
Thoughts RSW? RPM is higher on the Makita.
Fantastic reply, thank you. I'm going to order the Makita as well.Thanks for the info on the Rupes.
In my experience, Rupes always executes their designs very well and they've been around a long time and the Mille isn't the first forced rotation machine they've made so I'd expect it to be well built. Also, it has two options when it comes to backing plates - both five and six inch. The six inch backing plate will mean more movement between the pad and the paint for any given RPM. They also had the good sense to make the machine spin the right direction. At SEMA, I had a long and very good, both technically and personally, conversation with their designer who is a very professional and personable guy about why they should make a forced rotation with orbit machine and what characteristics I thought it should have. So....
The PO5000C and Rupes are essentially equal in weight, power and ergonomics, so it comes down to movement. The diameter of the orbits are, again, essentially equal. They both have enough and that's all they should have because, even though the machines can be counter balanced to deal with the vibration created by the orbit when the machines are running freely, the movement of the machine against the paint sends a vibration back through the machine from the surface. I bigger orbit, a bigger vibration. No way around it. They've both got it right.
So, even though the Rupes has the option for the bigger backing plate, I think the speed difference will give the edge to the Makita in terms of how much work you can get out of it in any given time. 780 rpms for the Makita and 535 for the Rupes means the Makita will create more movement between the pad and the paint. Because the Makita spins faster, it might vibrate more when it's in use. If it does, I'll put a weight on it where a handle might screw in.
That's why I've got a Makita on order.
Take Care,
RSW
So instead of shelling out $700+ for two tools, a gear driven da and a free spinning da you get both in one tool for $369.00. I'd have to say that's a major plus in the Makita's favor and a revolution in the da world.
FWIW. the new makita has a higher OPM and RPM.Yeah, it might be a revolution in the DA world, but it's not a revolution in Makita's world, because they already make this:
Makita BO6050J Polisher
That's the second version of that polisher, the original version they have been making for I think as long as I've been on detailing forums, so that's over a dozen years. Mike Phillips reviewed it here: https://www.autogeekonline.net/foru...546-makita-bo6040-removing-sanding-marks.html
I'm just saying that the concept (and sale) of the forced/free polisher has been around for a long time. Makita never got very much traction with it before, it was a very expensive machine, but that was back in the PC days, before we had expensive Flex, Rupes, and BOSS machines.
I mean here's a thread about it from 2007, which is about as far back as you can go on this forum: https://www.autogeekonline.net/forum/porter-cable-7424xp-dual-action-orbital-polisher/4568-7424.html
Agreed.Good of you to stop by, you've got a lot of insight to offer.
The Mille has higher OPM but less RPM than the Makita. How does this translate for correction between the two?
Agreed.
Both these machines should correct faster than random orbitals. They'll also have the advantage of being able to correct closer to inside edges and along the pillars and next to moldings and gaskets.
That said, in my experience, OPMs aren't that important on forced rotation machines. As long as there are enough to cross cut the spin, swirl marks won't be a problem. Higher RPMS should equate to a faster machine. Either machine will be a serious addition to anyone's tool set and should make anyone who doesn't have one a more effective detailer.
If you noticed what Mike said about doing correction on his demo car - that he'd usually use a rotary and follow with a machine to remove the swirls, that's been how I do it ever since I started using a rotary. These machines will make more of the first corrections with a rotary less necessary because they'll have a greater range.
More RPMS, more movement between the pad and the paint, is better IHMO but either machine for the win.
RSW
Get them both ;-)The new Makita looks amazing. I had planned on getting a Boss 21...
Get them both ;-)
I haven't did any comparisons between my PO5000c, 3401 or G21 yet...but so far found out PO5000c on speed 5 just jiggles and doesn't rotate...but speed 3-4 it has great rotation.
In forced mode it works great
.still not sure I like it better then my G21 but def love it compared to my 3401
