Desertnate
- Aug 5, 2013
- 6,261
- 304
- An actual knock issue. Hate to say it, but if all other elements are functioning correctly, then the knock sensor could just be doing it's job and reporting that it's hearing noise it shouldn't be. Timing or timing chain issues, piston slap, or excessive bearing clearance could cause this. I saw a procedure in the repair info that they have a tool for testing for excessive bearing clearance ( https://static.nhtsa.gov/odi/tsbs/2021/MC-10190044-0001.pdf ). This is concerning because it means it's a thing they've seen enough to make a way to test for it. That might be a question to ask your service peeps and see if they can let you know what engines they've been seeing that on.
What about bad gas or gas with too low of octane? Would the ECU retard timing enough to avoid knock, or could you still get it? Just thinking out loud and grasping at straws now... I've never tripped a light, but have had some very unhappy cars in the past due to both low octane/bad gas.
