Klasse Act
- Feb 21, 2012
- 27,873
- 3,005
- Thread starter
- #201
Thank youAgree. I can see this coming from here. They probably got the old ECU back and have figured things out and will likely take that as a way of not having to pay or document the issue that may or may not be the underlying cause. The Moss act is a little grey when fighting it. My wife is a lawyer and worked with a firm that took consumer law cases like this. In the end, manufacturers do a LOT Of testing and documentation, and in the end all they will really have to prove is that their factory/stock stuff works, and if a different tune was applied, then their factory warranty will no longer apply as it's no longer their full design that they back up. It's not even so much about proving the tune caused it, they have hundreds of thousands of cases that can prove these things don't happen to stock vehicles, and that so long as the design stays within their parameters and the consumer side will have to back up their argument to the opposite effect. Tunes are not like using different motor mount or hard-part. Software is much different. There's a reason why the phrase is "pay to play"
I've tuned or modified nearly every car I've owned and gotten lucky to have either avoided issues or at least the BIG ones. I'm leaving my Accord stock for a number of reasons, but this is one of them. These newer 4cyl. turbo cars in this generation of engineering are really already pushing limits and so tightly tuned that nearly everything/anything tosses a code somewhere. Not knocking the Koreans as the new products are pretty nice, but it's still my opinion they aren't long-term reliable or as well designed as others in the business.
I've not kept up with this entire thread but my assumption is after his tune there were some odd issues and now the dealer and manufacturer are looking into them. I personally would suspect it's time to trade that sucker in a cut-bait.
I'm not going to ask for you to read through but I'll give a "cliff note" version later but let's just say the issues didn't happen right away and a carwash is what has triggered the code here.
