ASPHALT ROCKET
SELF BANNED
- Mar 4, 2006
- 2,872
Frosty, is he able to get the Festool Shinex rotary and da?
Any idea how many OPM's each speed setting is? I know the range is 3500-10000.
Are you talking about the Griot's?
From pdf owner's manual http://www.griotsgarage.com/text/pdf/10750.pdf :
Speed Control Dial
The variable speed control dial is located at the back of the unit just under the power cord. To adjust the speed simply rotate the dial to the desired setting.
For polishing and paint sealant application speed setting 5 to 6 is recommended. For waxing speed setting 3 to 4 is recommended.
SPECIFICATIONS
Motor: 7 Amps, 850 watts
Power Supply Orbits/Minute: 120 Volts, 60 Hz 2,500 - 6,800
Pad Size: 6"
Orbit Diameter: 5/16"
Weight: 6.1 lbs.
I looked it up only because 10,000 OPM seemed awfully high to me.
That seems to be the polisher for the 6" polisher.......the 3" polisher does go up to 10000 opms.
I don't think most guys would use speed 5 or 6 to apply a sealant.:buffing:
Just to double check, when you asked the question above were you asking about the Griot's or the PC because that's what this thread is about. I"m not sure when it went off-topic and became the Festool thread?
I
I guess I'm just a little tentative cause I was told it's more powerful than the PC and I'm just a nervous nellie that way.
4.5 Wow!! I used speed setting 3 when I applied WG sealant 3.0. :buffing:
The Griot's Garage 3" Mini Polisher is as safe as they come, you can't hurt anything with tis polisher.
The Griot's Garage ROP acts just like a rotary buffer if you hold the pad flat so it definitely offers a lot of power.
But if it acts like a rotary buffer then doesn't that add an element of danger since you can burn the paint with a rotary?
Good answer Mike, but isn't true that it's better to have more power in case you need it?No, it still has a Free Rotating Spindle Assembly
Plus it's not just rotating, it's also oscillating, that's a lot different action than the rotary . Just for the record it doesn't have near as much power as a rotary, but if you hold the pad flat, it definitely rotates it under pressure at a pretty fast clip, fast enough that I don't stop it when applying excessive pressure and in the real world I don't apply excessive pressure when buffing out a car so the reality is it keeps the pad rotating and if you're cutting with it it keeps cutting. Isn't that what a rotary does?
By the way the G110v2 and the PC 7424XP do this also but the GG does do it with more power.
Again, all of the new generation dual action polishes are great tools for removing swirls and polishing paint to a high gloss. Not everyone wants or needs the most power.
No doubt about that!and then make their decision.
Whichever tool a person buys one thing for sure, the staff here at Autogeek and myself will be here to support you with your detailing projects and see you through to success in your garage.
