Eldorado2k
- Nov 9, 2015
- 14,583
- 729
He's gonna use Nu Finish. Lol
Nah, something with more TACHe's gonna use Nu Finish. Lol
Hey, man. You can set that stuff on fire and drop acid on it and your paint won't be damaged. Plus, it's cheap!He's gonna use Nu Finish. Lol
I have. I posted a blinded review of those silica coatings. I liked them. I wasn't sure how long it would be before I redid the hood, so I put Polish Angel High Gloss on the hood for now. Using quartz Max also.Did you try their Wet Coat or Cure?
Well, that answers the OP question. A good product if you want to strip an LSP.From The Gyeon website:
"While use of GYEON WaterSpot can affect the hydrophobic properties of the coating, so a coating of GYEON Boost or GYEON WetCoat may be in order. Avoid leaving GYEON WaterSpot on paint or glass for prolonged periods of time."
Well, for sure.
I put some PA High Gloss on and the car got wet today. Beading and sheeting are back, and now I can conclude it is all PA doing that part of the protection. No idea how much Mohs is left.
(Sent via my mobile device...)
Another good idea.Why not try some Essence Plus to "revive" the Mohs? Could then top it up with some Moonlight...
Although the hydrophobic properties may have been changed by the spot remover your protection is likely still fine. Essence Plus may help to restore it.
Absolutely. The more I think about it, a booster should make the coating last longer. Why? It will take the brunt of the beating and not the coating. With a booster, the hydrophobic effects will be that of the booster, not the coating, but it should be similar. I'd definitely stay within the same company for coating and booster applications.But a booster is good to use on a coating every other month though, agree?
Opps, too lateAbsolutely. The more I think about it, a booster should make the coating last longer. Why? It will take the brunt of the beating and not the coating. With a booster, the hydrophobic effects will be that of the booster, not the coating, but it should be similar. I'd definitely stay within the same company for coating and booster applications.
lolopps, too late![]()
sent from my lgls990 using tapatalk
