Coatingsarecrack
- Dec 9, 2018
- 7,884
- 572
I use Gyeon prep as my IPA wipe. I dont think its the products im thinking its maybe my technique.. ill try what Guz said about changing speeds and arm.
By chance do the imperfections look like it can be caused by "dry buffing"? I've been googling possibilities and ran into that topic. Looking back, I do recall the outer ring of my pads having little product. However, on the panel, I can clearly see the product being worked in circular motion.
Are you priming dry pads? If you aren’t do…. If your are focus in the edges. Technique is important but i doing a test spot with polish i woudn’t expect marring.
If you can’t figure it out give new products a try. Good luck.
