It must really be saturated because the PC 7424XP has plenty of power to rotate a dry pad.
After you clean the pad by pumping it up and down against the Grit Guard Insert you then lift the polisher up inside the bucket, with the lid still closed and turn the polisher on and let centrifugal force sling most of the excess water out of the foam pad.
After that you can squish any excess water still in the pad into a clean, 100% cotton terry cloth towel. Cotton absorbs water really well so that's why I use, you can try microfiber if you like also.
See the category for
Good Cotton Towels
The 4 minimum categories of wiping cloths
Slinging water out with a DA Polisher doesn't work as well as if you're using a rotary buffer so that's why you have to help a little with a dry towel.
:xyxthumbs:
