When Mike says that the "Cleaning Step" will take 4-6 hours to do in the OP:
"While this works, it means turning the polisher off, (now you're not buffing out the car, remember the time issue?) and grabbing your brush and then brushing the pad. Nothing wrong with this but when you consider how long it already takes to do the cleaning step, (about 4-6 hours for an average size car and that’s if your good at this and if you work fast and don’t take any breaks. So stopping the polisher and using a brush to clean the pad works but it’s not as fast or effective as using a terry cloth towel."
Is he saying "Just" the Compounding Step with a DA in 4-6 hours.
Yes!
That is what I'm saying.
Or does he mean, BOTH, the Compounding and Polishing steps can get done in 4-6 hours?
Ray
NO!
If you're working on neglected paint and doing a three step process,
Step 1: Compounding
Step 2: Polishing
Step 3: Sealing the paint (wax, sealant or coating)
The the first step, the compounding step using a free spinning tool like the,
Porter Cable 7424XP
Griot's Garage 6" DA Polisher
Meguiar's MT300
Griot's BOSS G15 or G21
RUPES BigFoot 21 or 15 or Duetto
Cyclo polisher
Then the first step, the compounding step is going to take you 4-6 hours depending upon how GOOD you are and staying behind the polisher and polishing paint. Every time you STOP to talk on the phone or text, or use the bathroom or fill-in-the-blank, the paint is NOT getting closer to the end of the compounding step.
That's what I mean by
If it's supposed to take 4-6 hours just to do the Compounding step, I have grossly misunderstood how much time I should be spending on cleaning and prepping my paint for my wax or sealant.
Here's the deal... in order to go faster you cannot simply move the polisher over the paint faster. Read the directions for any of the above tools and for doing paint correction, that is using a compound and a cutting pad to remove serious paint defects you're supposed to move the polisher SLOWLY over the paint as you make overlapping passes usually in a crosshatch pattern depending upon the shape of the panel being buffed.
There are two tools that can decrease the time needed for the correction step and these would be,
Rotary buffer
FLEX 3401
Somewhere on this forum I recently answered a question on choosing a polisher and I said something to the effect of using a FLEX 34001 to...
POWER THROUGH A DETAIL JOB
That's due to the gear-driven feature of the FLEX 3401.
Buy yeah... it takes time to do the correction step and the correction step is THE MOST IMPORTANT step. If you don't remove the defects in the correction step the polishing and waxing steps are simply going to make the remaining defects pretty.
This is also why I teach guys how to educate their customer when selling their services. Quality work takes time. There's no way around it. Time is money. If you're detailing cars you need to learn how to charge for your time otherwise you'll starve to death. That or like I teach in my classes, learn how to match your services to your customer so you can eat at the end of the day.
