Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
- Thread starter
- #101
Hi Mike, I have a question about the pad washer. I am thinking about purchasing the Universal Grit Guard washer today. Can this be used to clean the pads "on the fly" with my Rupes 21? I guess the only concern I have is the moisture after drying the pad. I would assume that the pad would not be completely dry after the drying step correct?
Would that little bit of moisture affect the performance of the Rupes compounds and polishes?
The answer to your question is "yes".
You want to use the Grit Guard Pad Washer to clean your pad right after use as that is the easiest time to "clean" the pad, (while compounds and polishes are still wet). But then set that pad aside to dry before using it again and switch to a clean, dry pad.
Kind of ties into this concept
one pad per panel
How many pads do I need to buff out my car?
Don't try to buff out entire cars with only a few pads. It will wear your pads out and wet pads don't work as well as dry pads thus >you< will be less effective in your work and buffing out a car will take you longer.
Now days, I ALWAYS take a picture of how many pads I went through to buff out a car. A picture tells a thousand words.
Here's everything I used for this old 2-door Ford
Full BLOWN RUPES Show Car Detailing on a Full Blown 1936 Ford Streetrod by Mike Phillips
