How to Mix IPA for Inspecting Correction Results
Mike, that was a very timely article. I had been following Avi's advice on the 90/10 mix of 90% IPA to Dawn.
I was talking to Jerry Bailey from Duragloss the other day and asked him about this. He said not to use any soap as part of a final paint inspection/cleaning process. He also advised to go with Mineral Spirits. I was not going to post his recommendation as I just figured everyone would want to argue, but after seeing your source having the same recommendation, I thought you would like to hear this. Same message from different, and highly qualified sources. That's more than enough proof for me. I have MS in a spray bottle and mist it onto a mf and gently wipe the area, followed up by a soft mf. I've been doing it on this GT-R I'm working on and it's working very well.
Great article Mike! I have always used and recommended 50/50 IPA, because that what everyone did. Now you have made me think about it more (mostly a good thing!).
I'm not a chemist and don't have any interest in becoming one. I make it a practice not to try to play the part of a chemist on forums either but it is important to try to reach out to contacts that do know about topics like this and get their insights.
I've seen paint wrinkled from exposure to strong IPA and it's not a comfortable sight.
A question (I apologize if you mentioned this in the article) -
Do you leave the IPA mixture in the bottle after you finish a project or do you mix a new batch each time?
I leave it in the spray bottles as we use it up fairly regularly for all kinds of things.
I always recommend following the manufactures advice as they tend to know their products and processes best.
Thanks for chiming in, I do appreciate hearing what other chemists have to say on the topic and I agree it seems to be a topic that can get some people kind of emotional...
I prefer how MS wipes over paint as compared to IPA but either way, when IPA is diluted with water it wipes a lot better then the stronger versions straight out of the bottle.
One thing for sure, while Isopropyl Alcohol is a liquid, that doesn't automatically make it a great lubricant and from my testing on clear coated black paint, it's pretty hard to wipe a highly polished black finish and not detects some marring from the wiping process.
The point of this is that if it's happening to a clearcoated black finish and it's pretty easy to see, it's likely happening to a finishes but it's going to be more difficult to see on lighter colors like silver metallics, etc.
So like you're doing, anyone else doing this should try to use, clean, soft microfiber towels and a gentle touch...
:xyxthumbs:
Save all the guesswork and buy some Griot's Pre-Wax Cleaner for inspecting!
Great thread! Thanks Mike! I wonder if there is a way to determine what is more effective in removing wax or sealant? Would it be Dawn, IPA, clay with QD, or the mineral spirits?
I think I covered that in the article... bottom of the first post...
Mike Phillips said:
Personal Recommendation For IPA
If you want to chemically strip paint to remove any compound or polish residues so that you can accurately see the true condition of the paint after any correction steps, then I recommend using approximately a 10% dilution of IPA to water solution. This is a safe approach to remove any residues masking the true results of your process to the paint without the risk of causing any harm.
You can also opt to use Mineral Spirits instead as they will also remove compounding and polish residues.
Checking Your Test Spot vs Checking the Entire Car
Theoretically, if your use IPA to chemically strip your Test Spot and after stripping and inspecting the results look good to your eyes, then theoretically if you duplicate the same correction process over the rest of the panels you will also remove all the defects and leave the same finish behind that you saw in your Test Spot.
Assuming all the panels have the same type of paint, then you shouldn't have to continue stripping all the paint on each panel, just keep doing the same good work you did for your test spot and trust in your skills and ability.
You can check each square inch as you work around the car to make sure you're doing as good of work over the rest of the car as you did in your test spot, that's an option and choice each person can make. I tend to check my Test Spot and if it looks good then simply repeat the process over the rest of the car and trust in my skill and ability to duplicate my process over and over again with little variation.
Chemically Removing Waxes and/or Paint Sealants
Note this article is addressing the dilution strength for removing compounding and/or polishing lubricating oils sometimes called fillers during the paint correction steps. You can also use this to try to remove any previously applied wax or paint sealant, but while I was speaking with one of my chemists friends about this topic they told me that Isopropyl Alcohol is not effective at removing some polymer products.
Since there's no way of knowing at the molecular level what's on the surface before you wipe, and no way of knowing if 100% of everything has been removed off the surface after you wipe, therefore there's no way of knowing if IPA, (in any form) is effectively removing 100% of any previously applied wax or paint sealant. You can hope... you can assume... but you can't know 100%
If you're dead set on removing any previously applied wax or paint sealant by chemically stripping the paint, then a combination of using both a 10% solution of IPA to Water followed by wiping with Mineral Spirits should remove most, if not all, of any previously applied wax or paint sealant.
Personal Recommendation For Removing Waxes and Paint Sealants
To remove any previously applied wax or paint sealant, I recommend using a light paint cleaner or a light polish applied by hand or machine. A light paint cleaner or abrasive polish will effectively remove any previously applied wax or paint sealant AND leave the paint looking clear and glossy. I call this working forward in the process because the goal is to create beauty.
Chemically stripping the paint will tend to dull the paint; it certainly doesn't increase gloss and clarity. You don't see the dulling effect unless you're working on black paint and repeat the process multiple times. Since not everyone works on black paint, and you're not going to make stripping your car's paint a daily routine, it could be you won't see the dulling effect on your car's paint but it does take place.
Wiping a clear coated black finish over and over and over again with any type of solvent isn't going to make the top clear layer of paint more and more clear, it's going to do the opposite, that is dull it down.
So chemically stripping paint is what I call working backwards in the process. I, personally, prefer to work forwards in all my detailing projects but do understand the reasons why some people want to chemically strip their car's paint, or their customer's car's paint, and each person can decide what the best approach is for their needs.
And again, since you're not chemically stripping the paint as a "practice" but only during a detailing session, the dulling effect is not an issue, but I wanted to point it out just for the most detail oriented detailing enthusiasts or Pro Detailers reading this article.
I do my best to cover every point or question a person might have when I write an article...
:D
Thanks for covering in such great detail an area that can potentially do harm to a car's finish when the goal is the opposite. I didn't think of it like I should have before I used IPA in the strength that I did (50-50) and your article enlightened me. You're the man!
After initially trying the IPA approach recommended by so many here I found that it worked but like you discovered, a 50 / 50 mixture was just way too strong. I've backed off on the dilution to a "more friendly" cleaner however I find myself using Mineral Spirits more and more becuase it just seems to do a much nicer job..:props:
This wasn't a very exciting article to write but because the topic comes up once in a while and after looking all over the Internet I couldn't find any articles that were valid or helpful on the procedure. Actually I found zero articles, just basic recommendations with no detailed information or recommendations based upon any factual substance. So I made the decision to do some research and then write an article on how to do this procedure safely.
It's important to check your work and make sure the results you're seeing are accurate but it's also important to work smart.
Like the old saying goes...
Work smarter, not harder...
And then there's the other topic about stripping the paint after all the polishing steps are finished so there's nothing to interfere with the bonding of some paint protection products. Again, it's important to follow the manufactures directions but it's also important clean and strip the paint in a way that's safe and doesn't harm the paint at the same time.
I'm not sure if I've posted this to any other forums but that's something I'll do in the future just give others some guidelines and suggestions. Feel free to share the link to this thread to any of your forum buddies on other forums if they have any questions about the procedure.
Great Info! I feel smart after reading that, not really..
But I see why you posted so many options after, the term to each their own comes to mind..
This may sound like a dumb question, but I'll ask anyways. Will using MS soften the finish at all as compared to using an IPA mixed correctly? I am just curious to know, should I wait a certain amound of time after the MS or IPA evaporated before polish, such as a few minutes, or can I go back to it? Since the polisher will be generating some heat, I didn't know if there is a period I should wait
It has been mentioned that IPA contains no lubricants, and is probably not the best idea to wipe it across a polished surface with a lot of pressure. Is blotting IPA applied to a MF towel on the surface as effective as wiping the IPA across at removing any kind of residual polishing oils left behind?
What are your thoughts on using something like PrepSol?
I have 99% isopropyl alcohol from work that we use to clean fiber optic connectors with. I used this to make my IPA solution in a 36oz. bottle. I went with a 15% solution for now. I might have to back to 10% cause 15% might cause damage to the paint.
This may sound like a dumb question, but I'll ask anyways. Will using MS soften the finish at all as compared to using an IPA mixed correctly? I am just curious to know, should I wait a certain amount of time after the MS or IPA evaporated before polish, such as a few minutes, or can I go back to it? Since the polisher will be generating some heat, I didn't know if there is a period I should wait
Actually it's a very good question and in my article I actually state,
FWIW
My colleague stated that Mineral Spirits will tend to penetrate deeper into automotive paints, but it's safer than IPA.
I'm not a chemist so I don't like to type over my head but the big picture is as long as you're using common sense then wiping with either on factory baked-on paint and then waiting for a few minutes you should be able to go right back to work without any issues. People do this everyday and you don't see a plethora of posts on any detailing discussion forum about any issues or problems people are running into with this practice so that's a big picture indicator that there are not any problems.
I would strongly agree with your statement. IPA doesn't feel as good to wipe paint with as MS, just test yourself sometime. IPA is a liquid but a poor lubricant. Definitely don't replace the oil in your car engine with IPA :D
Blotting is always less aggressive to paint than wiping but probably not as effective as loosening and removing trace oils.
One thing for sure, don't take washing and waxing your car to the point of becoming Rocket Science. :laughing:
I haven't wiped good paint with it lately and in order to get some I have to go to a PBE store, but from memory it's about like wiping with IPA
Prep-All
  1. What are you working on?
  2. What condition is the paint in?
Definitely everyone has their own personal preferences and opinions....
I wrote this article because I couldn't find a single article anywhere on the topic, just vague recommendations with no specifics. If you read the forum enough you'll come across threads where some forum members tend to get emotional about this topic.
Hopefully this article will act to help people make an informed decision on how they want to proceed for all their own personal detailing projects.
Chemically stripping paint is recommended by a handful of manufacturers while the majority don't specifically state it's mandatory in order for their products to work.
So everyone in the end will have to do some level of their own research and come to their own decisions. This is actually another article that I asked for volunteers to take a stab at writing and when no one stepped up to the plate I wrote one.
prep-all doesnt say if it is paint safe???
It's a product formulated for and targeted towards body shops for prepping panels for new paint.
People use it for a wax and grease remover to chemically strip paint. That doesn't mean it's good or safe for the paint as it's a solvent, not a beauty enhancing polish or wax.
I address an option for cleaning paint that's safe in post #4 of this thread,
Mike Phillips said:
Personal thoughts on removing previously applied waxes or paint sealants...
My personal opinion and habit is to use a light polish or paint cleaner to remove any previously applied waxes or paint sealants to get down to a fresh base.
Not only will a quality light polish or paint cleaner effectively remove any previously applied wax or paint sealant, it will also create a clear, high gloss surface perfect for application of wax or paint sealant. This is what I call working forwards in the process.
For those that are concerned about proper bonding of a wax or paint sealant to the paint due to any trace residues left behind, see my article,
Miscible and Immiscible - Wax and Paint Sealant Bonding
:dblthumb2:
1. Just machine polishing and looking for the most effective way of removing any kind of left over polisihing oils that could cause concealing
2. Factory finish above average and not neglected
Given the possible issues with IPA and the exposure to solvents from mineral spirits, why not just use Optimum Power Clean or Griot's Pre-wax Cleaner or Paint Prep if you're concerned about residue?
[/LIST]
1. Just machine polishing and looking for the most effective way of removing any kind of left over polishing oils that could cause concealing
When working on a factory finish as long as you're using common sense you're not going to harm the paint with anything listed in this article. The fastest stripper to make and use is just get a 16 ounce bottle of 50% IPA and pour it into a 32 ounce bottle with the other half water and this will peel any residues off so you can see the true condition of the paint. That's the fast, no brainer way to create your own chemical stripper.
MS wipes a lot easier and it doesn't feel so antagonistic to the paint.
Washing the car gently is another option but that takes time and gets the car all wet again.
Try not to make something so simple too complicated... :props:
All of the above are great options too...
IPA leaves the paint faster than mineral spirits or prepsol does. IPA can leave within a few hours while other slower solvents can remain much longer.
Check out this product:
http://www.autogeekonline.net/forum/product-reviews/42133-review-carpro-eraser.html
http://www.autogeekonline.net/forum/product-reviews/42331-eraser-vs-ipa-video.html
