Re: Hair line scratches on Wood Trim?
Thanks Mike,
That area is the worst of it, the rest is in pretty good shape. I think with that being the flat part in front of the storage compartment between the seats, it has had a lot of things dragged across it over the years.
You guys could invent/design some sort of 1" or so size pads to fit a drill or dremel to get to these areas.
rops:
I am a little apprehensive but, that's all part of the fun right?! These panels can be removed from the car and make it possible to use a machine. Then you risk the possibility of causing larger problems, rids, breaking attachment pins, etc.... Or maybe it's time for a road trip to AG.
I am going to go after it in a test spot as you suggest with new SX. I will report back when I get there.
Thanks Mike,
