Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 10
Re: Hair line scratches on Wood Trim?
WestEnd,
After reading the above description of your experience in rubbing out small trim panels like you have inside your car...
Does what I wrote previously in this thread now make more sense sense? See the portion in bold blue
Did what I describe match your experience?
Update and I am excited!!! This new SMAT Scratch X is amazing. The old one did hardly nothing and this new formula is quite different.
But, WOW! This hand working takes a lot of time and patience. But considering my hand RPM versus a machine, it all makes sense. For the Pros to charge accordingly this would be a costly process with small area results.
I noticed it took many applications and talk about working small areas. I noticed two inches by two is all the larger I could go to feel effective and smaller than that was better. I got my best results with fast movements and a lot of pressure with a sponge applicator.
WestEnd,
Technique is everything when working by hand...
When it comes to working on small panels like these trim components, the problem is usually having enough room to move your hand back and forth fast in an effort to abrade the surface to remove enough material to level the surface.
If the trim component is out in the open it's not a problem, but as the trim component is surrounded by things like displays, switches, buttons, levers, etc, as these thing get in the way you can't get in there and put some passion behind the pad.
