Klasse Act
- Feb 21, 2012
- 27,827
- 2,920
I would only use foaming surface prep if I were doing a massive detail
So mix with BSD then buff off? Might be ok, like mixing hydro 2 with Merlin’s. I’d check to see if it has any “soaps” in it wouldn’t want to buff on buff if it did and BSD wouldn’t foam in a sprayer.
Griots doesntcrecommend to use on coatings. Be careful with LSP’s
I would only use foaming surface prep if I were doing a massive detail![]()
Buy the smaller size of Griot's Garage foaming surface prep, I plan to do so with my next order.
That's right, there was a bottle issue. Amazing some companies can do something about a bottle issue while others can't or will notHave they released it in that size? I've only seen the gallons. They initially rolled out the line with 35oz available for all 3, but the Surface Prep proved to not be compatible with the plastic of the 35oz bottle so they switched to gallon only.
Did a quick check on Griot's site, AG, and DI; DI shows "pre-order available" for the 35oz size with an estimated ship date of 3/29/19. Not sure if that's just a placeholder date...
Thanks for the input guys.
I should have been clearer - When referencing the Foaming Surface Prep, I only meant that Griot's presents it with multiple application approaches - You can foam it, or spray it via standard spray bottle mixed at 10:1 as a bug/road grime pretreatment per their info.
While I'd love to try the Surface Prep, I'll never go through a gallon of the stuff so it's not likely I'll pick it up. If I did I totally understand any product in it's category requires care and consideration. (In regards to potentially degrading the LSP).
Coatingsarecrack - From all the reading I've done, I don't think the Poly Gloss has any amount of soaps in it. But, in the end I'll still probably stick to using it as specified on the label.
Going through all the info I printed out when the BOSS Foaming stuff was released (Jeff Brown shared some links on the sister site), they do mention with the Foaming Poly Gloss that you can mix it at .5oz to 60oz water in a sprayer and apply it after washing but before rinsing.
Not really much different than when using it with the foam cannon, but this at least gives you the option to use it without dragging out more equipment. I guess it's still functioning as a drying aid, just not in the way I always think of them (Wash car, rinse car, spray drying aid, dry car).
Maybe sometime for kicks I'll do a spot on my roof at that dilution without rinsing it off and see what happens. My curiosity on this stems from seeing products like the new Meguiars Hybrid Ceramic wax where they tout it as a Spray on/rinse off product, but people are spraying it on and buffing it in with positive results.
