Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 8
- Thread starter
- #41
Too me An AIO polish is polish with sealant/wax.
Cleaner wax is wax with cleaners , non abrasives
A few years ago a forum member that was banned of AGO tried to make the case that AIO's were NON-abrasive and cleaner/waxes contained abrasives and his claim was that it was this difference that separated AIO's from cleaner/waxes.
I then posted examples of AIO's that had abrasives and AIO's that didn't have abrasives and cleaner/waxes that had abrasives and cleaner/waxes that didn't have abrasives.
The point is there is NO difference they are just different words for the same category of products. That is products that will do three things,
- Clean
- Polish
- Protect
Both can have glaze .
The word glaze is now days... a catch-all-term. Companies use it to describe one-step cleaner/waxes and synthetic sealants and also polishes.
Two examples of TRUE glazes in the historical sense of the word are,
3M Imperial Hand Glaze
Meguiar's #7 Show Car Glaze
Jeweling wax just combined a cleaner wax with an AIO polish..
I'm going to stick with this definition from the first post of this thread,
Mike Phillips said:Jeweling Wax
Definition: An ultra fine cutting polish and wax combination that when used with a soft foam finishing or jewelling foam pad will maximize paint gloss, shine, depth and clarity while leaving behind a layer of protection.
I started a thread about jeweling with a DA months back...just assumed any polish on the chart rated with a 1 could be considered for jeweling.. Yet none were actually "jeweling waxes"
There are jeweling polishes and to me this would be two things,
1: An ultra fine cut polish.
2: An ultra fine cut polish that uses top notch abrasive technology.
Just because a polish exists with the word ultra fine cut doesn't mean it actually is on the same level of quality and performance as all quality ultra fine cut polishes.
To bring up a question that really wasn't answered in said thread
What would be the best for jeweling with this new product?
Something like car pros gloss pad?
Or non abrasive wax pad?
Because like most compounds, polishes and cleaner/waxes you can simply vary the level of cut or NON cut by the aggressiveness or NON aggressiveness of the pad used the same applies to a jeweling wax.
If you're using it as a stand-alone product for production detailing, that is you're not doing any other compounding or polishing steps BEFORE using a jeweling wax as I share in the first post then you could use a foam polishing pad.
Mike Phillips [B said:Perfect product for high quality production detailing[/B]
Production detailing usually has a negative connotation associated with it and sad to say all to often when a car is machine buffed using a one-step product by machine the results are either hologram scratches, buffer trails or micro-marring that leaves the clearcoat hazy looking.
The culprit for mediocre results when doing a one-step process to the paint by machine using a one-step product is either the product, the pad or the tool and in some cases all three factors.
With a true jeweling wax you can restore a shiny finish using only a foam polishing or finishing pad with just about any machine polisher for customer pleasing results. A true jeweling wax will remove the risk of mediocre results which are common in the production detailing world while providing technicians with a simple and easy to use product. The key to doing high quality production detailing always starts with setting the expectation of your customers and that's means educating them with a minimal understanding of the paint on their cars and the paint restoration process.
If you're using it as your LAST machine polishing step to perfect the paint after a dedicated compounding and polishing step or after say only a dedicated polishing step (with something like a medium cut polish), then you could use it with a foam finishing pad or a foam jeweling pad.
