These pads are NOT hydrotech foams, as those types of pads don't do well with the heat created from 21mm polishers or aggressive polishing with these types of machines.
They will be available in about a month or so, and are made to be used on large throw machines WITH a center ventilated backing plate.
HD-Orbital pads are great for many reason, one being that they are very easy to clean/dry and run cooler that other foam pads on the market.
They are extremely balanced and keep pad rotation very well. The pad will not concave or (opposite) bowl do to heat creating the maximum surface contact.
I'm hopeful, and think everyone will really like them!rops:
Looks very cool. What sizes will they be available in? I'm thinking they'll do well on the 3401, too.
Mark,
These pads were designed to be used with a ventilated backing plate. They really need to have a vented backing plate with a center hole to operate properly, like the Rupes polishers. I actually will test them for durability and I can update you with my results as they weren't designed to be used with that polisher.
On long stroke machines they are GREAT!
Thanks for the clarification, David!
Mark,
I did do some testing, and I WILL continue to until I am 100% confident they will work with the 3401 without any issues.
I used or 6" (to fit a 5" plate) on both on the LC 4" plate and also the factory 4 3/8" plate and they seem to work great so far !
Mark,
That is good to hear David, i have a 3401 as well so I will be following this also
Sent from my SPH-D710 using AG Online
Corey at carpro said next week sometime, but it seems like it keeps getting pushed back.
Sent from my XT907 using Tapatalk
