ASPHALT ROCKET
SELF BANNED
- Mar 4, 2006
- 2,872
I think I'm going to give 1Z a try. Plus, I can use it on my interior panels as well. :dblthumb2:
Actually 1Z Cockpit Premium would be a better choice for the interior.
How does opti-bond compare to 303 on the tires as far as gloss/sheen? I clean/scrub my tires with a brush every saturday, and re-apply, so I don't need something that last really long!If you really want low gloss, use a black dye like Forever Black to make your tires jet black and flat as a surf board. I have used my 303 Protectant on tires but it doesn't last long at all... Definately reserved for the interior now that I have switched to Opti-Bond.
Opti-bond is a bit more glossy than 303, but that means it is still not glossy at all. It is a satin look but Opti-bond makes the tires look much deeper in color when compared to 303. I bottom line; Opti-bond is much better suited to dressing tires than 303 in my opinion, and leaves a better finish.
If you have tight wheel wells, cut Meg's Hyper Dressinhg 4/1 put it in a small pump sprayer, cheaper, easier, and better.303 was my favorite until I tried Opti Bond. I agree with Christian.. Opti Bond looks better to me and is easier to apply since it is a gel. It is also great on wheel wells. I use AG microfiber gloves to apply to the wells on my XLR which has tight wheel wells si
Just posted a review of Wolfgang Black Diamond Tire Gel with lots of before and after pictures...
Wolfgang Black Diamond Tire Gel - Review and How-to
Here's a sequence of close-up shots showing before, half & half and end results...
:xyxthumbs:
Optimum sells a tire shine spray. Wouldn't that be the same thing?I consistently use Opti-Bond, you can also tone down the shine by diluting it with distilled or tap water into a spray form and that has really worked well for me.
