Man..so much info on this system, but no clearcut answers.
I just purchased a new Z06..black. Thank gawd, its only been in the showroom, and none of the dealership clowns put a buffer on it. It does, however have the usual micro-marring from washing, dusting, etc.
I am very skilled with a rotary- but see no reason to induce buffer trails or the finesse and work you need to put in to use a rotary on black.
I have a early model PC D/A but I'm thinking about either trying the new Meg's MF system with a new Flex machine, or buying a new flex and using my tried and familiar foam pad systems.
Any recommendations??
I'm not sure you need that much cut as carsmetic just pointed out on a new car if it's in good shape unless it has some deeper defects. a PC or Flex with something like M205 or Menz. 106fa and a polishing pad might be perfect. IMO a black Z06 would deserve to be jewled with Menz. PO85rd or 3M Ultra-fine with a polishing pad... I'd also clay it before polishing... Good luck!
too many variables with the different types of paint for clear cut answers. If your car is in that good of condition you dont need the mf system. the flex does not do well with mf discs.
5" pads on your old pc will be very capable of taking care of your vehicle if it is just micro marring you need to deal with
+1
