When would you use SB instead of MF?Both pads will have their purpose. I don't plan on removing either from my supply any time soon.
That's mostly what I do. Perfect.If an owner wants a single step polish, the MF pad is the one to get.
On some paint, from what I hear. There are a lot of finishes out there that won't finish even close to LSP ready with the compounding pad. Just from what I've seen.If an owner wants a single step polish, the MF pad is the one to get.
If this is the case, what product would you use for a one step? 151?
If they both have to be followed up then why does it matter? Just wondering. I would want to use the combo that removes the most defects. I understand Surbuf will be overkill for some vehicles, but on the other hand the MF system won't be aggressive enough.While that is definitely a possibility, the MF pads will finish down better than a Surbuf. If a MF pad left it hazy, the Surbuf pads would leave the finish more hazy.
:iagree:
These are both "tools" in your detailing tool arsenal.
Keep in mind that with all the feedback being collected that chances are good you'll see some new additions and/or improvements to the system, which includes both pads and chemicals.
