Eldorado2k
- Nov 9, 2015
- 14,584
- 734
I’m slowly regretting CarPro Essence Plus. I’ve used it twice and I really didn’t notice any improvement/repair on a coated surface. It also left the surface duller. I used CarPro Gloss Pads on a Rupes 15 at low speed to apply. I’m just not impressed enough to recommend this product.
Mine is Meguiars UFF. Yea it was fast but it doesn't do anything
Sent from my SM-G930V using Tapatalk
It doesn't do anything. I applied it 2 consecutive days to ensure even coverage and it had over 24hrs to cure. Then the rain started and it had zero sheeting or beading properties. I have crazy amount of water spots and dirt seemed to stick worse....basically everything opposite of what I've heard, seen, read on the productI heard a lot of people like UFF and it lasts for a ridiculous amount of time. Never tried it myself, but what didn’t you like about it?
Stoners Interior Glass Fog wipes, with a caveat. I applied it just to get use out of it and my windows which never had fog problems fogged the next day. They don’t even clean either, which the RainX ones do. The caveat is that my 2 year old son carries the small 4 oz bottle around and spins it on the floor. He really enjoys it and I prefer him using this bottle over the 4 oz, significantly costlier and more useful PBL wheel and glass coating bottles!
I thought Reload should be applied within 1 hour of cquk? No?I would have to say C.Quart UK 3.0 is at the top of my list. Spent a full day prepping the paint so I could apply it. Spent 2 days on applying it because there is a wait period in between coatings. Then waited 3 more days for the initial cure process before applying Reload on it so I could finally drive. I don't know if I had a bad batch or what, but it rained less than 24 hours after I had pulled it out of the garage. And it already stopped its hydrophobic action. So I did a maintenance wash, and reapplied the Reload again. I had the same results as before.
Unfortunately for me, I did it on my other vehicle too. Did same the process, and spent the same amount of time on it.
One day I may try a better product, but for now, I'm spent on ceramic coatings.
Sent from my SM-N950U using Tapatalk
"If one molecule of that crap hits this truck, you're in for a really, really bad day".
From what I had read it didn't matter when it was applied as long as it was after the 24 cure period of the last application. I don't know maybe I did it wrong. There were so many different answers on how to do it out there. Of course, if I was using this forum back then, my answer would have been more straightforward.I thought Reload should be applied within 1 hour of cquk? No?
Sent from my Mi A1 using Tapatalk
Regarding Cquartz UK, my understanding is that it's an hour IF you want some protection as the coating is curing. For example, if you have to send a customer car home after applying and it might get wet. I believe if you can't get it at one hour it needs to be at least 24 hours. When I did some testing I had coatings fail when not giving them enough cure time before getting wet. Cure time is also temp and humidity dependent. Unless it's hot out it seems like 24 hour is the absolute minimum cure time before getting them wet.
FYI, I had good results with Cquartz.
