Ok, so the first pic of the primed pad, shows excess product?
And the second pic shows a primed pad with less product?
Guys....like I said in post #3, I really think the Kevin Brown Method is a "must use" for M105.
Read Kevin's posts (thanks Kevin!) in this thread and give them heed!
Yes.
After you've primed, apply a circle, X, or dots of product to the pad and polish!
Clean the pad occasionally to remove abraded residue, reprime, and apply circle, X, or dots again.
While not everyone sees the benefit or cares to try this... for me it works fantastic.
This is for DEFECT removal, by the way.
For final polishing, you still prime, but then remove excess product by placing the pad onto a microfiber towels and run the machine a few seconds. This will minimize the chance that abrasive clumping might occur as the blobs of M105 fall out of the pores. Apply a bit of M105 to the pad, and polish using a slow speed setting (enough speed so that the pad still rotates, but only 1 or 2 turns per second), move the pad about 1-inch per second, and keep an ample amount of pressure on the machine- just enough so you are sure that the face of the pad is absolutely in contact with the paint surface. Don't decrease pressure off at the cycle.
You know what method works really well to combat M105's short working time? Mineral oil(baby oil.)
I learned this trick when I first ran into a car with a sticky clear coat. I looked around and found 2 ways to combat the polish from gumming up and that was switch to a DA polisher or use a drop of mineral oil every 2-3 new sections.
When the customer returned for a follow up and I tested the two methods. DA works well but the mineral oil gave me the biggest surprise. Put some mineral oil in a pump sprayer and used 1 mist every 2-3 sections, cleaning the pad between each new mist. Let me tell you, it made working with M105 a dream. The pad was so smooth and buttery, similar to working with OP II, and working time was really long. You could basically work it forever if you wanted. It still dusted but not as much as it usually does and I saw no real lost in cutting ability. Use mineral spirits vs IPA to remove the oils and you're good to go.
This is an interesting option and I might give it a try.
I hear mineral spirits is used for "other" problems but it may have found another home in the shop! Three drops for you and a tablespoon for me!! Not enough Oooooo's in smooth! :laughing: :laughing: :laughing:
I think the Kevin Brown Method for priming the pad is a must with M105.
This helped greatly in terms of giving me a longer working time before flashing.
Can you please give me an idea of the KB method as I cannot use 105 with the short work time.
Uhh.. :idea: Read this thread? :dunno:
If it doesn't help, read this: http://www.autogeekonline.net/forum/auto-detailing-101/21634-what-s-kbm-method.html#post268303
There's a gaggle o' guys posting here on AG that have had great success playing with priming and pressure and speed and pads... they always happily chime in.
Some guys are happy with the results they get just by slapping a pad on the machine, applying some product, and turning it on and gettin' to the business of polishing!
Not trying to pull you away from this forum, but there's a TON of info in regards to methedology and general discussion about random orbital theory on another detailing forum based somewhere... where in the world was it... in the UK I think...rops:
I am sure you were thinking oil but you said spirits.
I gave up on M105 a long time ago.
...If only Ultimate Compound was sold in gallons...
Thanks, I will read and explore!Uhh.. :idea: Read this thread? :dunno:
