- Thread starter
- #21
Is the gray Kobrajet stiffer than the smooth blue version? Several years ago my research said to get single wire coil vs double wire coil as it was more flexible and the electric PWs don't require as heavy duty of a hose.Upgraded my PW to the Active 2.3 and Active recommends a steel braided hose. The Kobrajet isn't steel braided but it's actually a bit stronger than the included hose and Flexilla is on the "do not use" list of hoses.
How do you like the Active 2.3? I have the old VE51 and it churns out 1.8 GPM which isn't bad. I've had it for over three years now and it's still chuggin' along just fine. When it dies I'll get the newer version.
