Does this look like a decent "starter kit" for a poor college student?
That's a good start for someone new to the rotary buffer.
The Kompressor pads are easy to control as they are very flexible.
The Intensive Polish is a medium cutting polish with a long play time, you can't get into too much trouble with it and it doesn't look like your Blazer needs a lot of correction work from the looks of it's overall appearance.
The hardest part for you will be to create a 100% swirl-free, or hologram free finish using ONLY a rotary buffer. It can be done but it usually requires,
- The right pad
- The right polish
- Expert technique
- A paint that is polishable
You can control the first 3 but not alwasy the last item and you really don't know until you do some testing and then inspect the paint in good lighting like bright sunlight.
If you really want to know the true results you would want to strip your test areas and then inspect in bright sunlight, for stripping any residues left by the polish you could wash with a detergent wash or wipe the paint really well using IPA, APC or MS
If it's not a concern to you then you could simple go to wax and any really shallow swirls will be masked by the Mother's Carnauba Wax.
Many online enthusasts are focused like laser beams on creating proof-positive swrirl-free results before applying a wax or sealant but that's a decision each person has to make for themselves.
One way to inusre a swirl free finish is to do what I always type out as,
Change the action of the tool
That is after the rotary buffers steps switch over to a tool that offers ocillating action instead of just rotating action, that could be any of the below taken from this thread,
How to choose the right polisher for your detailing project
Single Head - Random Orbital Polishers - Free Rotating Spindle Assemblies
Porter Cable 7424XP
4.5 AMP
500 Watt Motor
5 pounds
3 Year Limited Warranty - 1 Year Free Service - 90 Days Money Back
Griot's Garage Random Orbital Polisher
7.0 AMP
850 Watt Motor
5.5 pounds
Griot's Lifetime Warranty
Griot's Garage 3" Mini Polisher
2.0 AMP
240 Watt Motor
Meguiar's G110v2
4.2 AMP
430 Watt Motor
5 pounds
1 Year Limited Warranty
Dual Head - Random Orbital Polisher
Cyclo Polisher
Hybrid - Forced Rotation Random Orbital Polisher
Flex 3401 Forced Rotation Dual Action Polisher
7.5 Amps
590 Watts
6 Pounds
