06CivicSi said:Go with a honda oil filter... and change your oil every 3k miles. The oil and filter are the life of your motor.
Bags said:Ok Im at a loss BITOG?
Well said I use Black Stone Labs for my oil analysis using Motorcraft (MC) 10w30 I can go 6,000 mile between changes (using MC FL1A) on my lil o'l 5.0 with 136,000 mile and I drive it like I stole it. The Fusion gets MC 5w20 and goes 5,000 using MC 820S filter. Both oils are synthetic blends, you can uses MC oil in any car and @ 2.35 a quart MC oil is hard to beat. Paper filter Wixs for me. One oil filter that hasn't been mentioned as has scored high on BITOG is AdvanceAuto brand filter they are good. K&N is good just price compared to others that perform just as good if not better. Here was the last sample I sent out and what it scored (they like my V8Al-53 said:I have been using Amsoil and Puralator Pure1 filters...I go 10,000 miles between changes with a Used oil analyse at 5000 when I change the filter....and the test comes back perfect...saying my oil has not yet reached half life..and no engine wear detected...Amsoil is fine oil....they claim 25.000 on it but I change it at 10,000...its a group IV and V oil meaning pure synthetic base stock....not group III like mobil...
it is very important to use a good air filter to keep contaminants out of oil...I use a Pure 1 there also....I was told not to use a K&N since it does not filter well and the oil can mess with the MAF sensors....
When I had to have my oil pan gasket changed under warranty at 34,000 miles..the mechanic came out and told me the engine was as clean as new and told me to keep doing what I was doing....I even brought my own oil when gasket was replaced so it would be put in instead of thier oil...
as far as filters...the good ones are
Wix
Pure1
K&N...but need a 1inch socket for them to remove and put on....
Napa gold
Baldwin
Motorcraft
Bosch
Amsoil which I believe is a Hastings or Baldwin
those were listed as the best constructed and best filter media...with non restricted flow...
I recommend a used oil analsyst to any one who drives a car hard or any performance car....at least once a year.....they range fro 20.00 to 30.00 a test...well worth it...may find something wearing that you do not know about...
AL
