Polar White Mercedes C63 - Detailed by Lawrence
lawrenceSA
A good client of mine recently purchased this vehicle and knew that despite it being new, there would already be contamination on exterior surfaces and some below-surface defects like swirls and scratches. By removing these and then 'sealing it in' with hydrophobic 'wax'/'sealant'/'coating' [which will depend on your specific situation] you make the car easier to keep clean in a way that reduces swirls
The vehicle was detailed near the beginning of March.
The engine bay had a lot of 'dusty' type dirt (as opposed to say an old oil leaking engine that was greasy/grimy). The carpeted section on the underside of the hood was brushed out then the engine bay blown out using an electric blower and then gently wiped cleaned using Mothers Carpet and Upholstery cleaner. The engine bay was cleaned using Carchem APC @ 1:5, various brushes, q-tips, microfibre towels and a dedicated (to the engine bay) lambswool wash mitt. The plastics were dressed using Carchem Vinyl and Rubber dressing, and the painted surfaces protected using Gyeon Cure.
Before
After
Arches: Rinsed with a pressure washer, sprayed with Carchem APC via a foaming trigger head and allowed to dwell and then agitated with a large Wheel Woolie. This was followed with another pressure rinse.
Tires: Cleaned with Carchem APC and a Mothers Tire Brush and later dressed with Carchem Trim and Tyre Dressing
Wheels and brake calipers: Rinsed with a pressure washer then cleaned using Carchem APC and a Wheel Woolies and a Autofinesse Boar Hairs brush and dried. The wheels were then thoroughly sprayed with Carchem Revolt which was agitated after being allowed to dwell for a few minutes, using the same brushes, and then thoroughly rinsed and dried them.
Carpro TarX was used to remove any tar spots. The wheels were then foamed using Turtle Wax Hyperfoam when the rest of the car was being washed - this would ensure there were no remaining residue on the surface. They were then sealed using Carpro Hydro.
Door shuts, boot shut, window rubbers, fuel flap, badges etc: Cleaned using Carchem APC with Autofinesse brushes and then pressure rinsed. Autofinesse Tripple was then used to further clean these areas and leave behind some protection.
Wash: Pre-foamed using Turtle Wax Hyperfoam via a foam cannon
Followed by a 2BM wash with Lambswool wash mitts and Carchem Luxury Shampoo.
Dry: ONR at QD strength with WW Drying towels and an electric blower
Decontamination: Carchem Revolt, Carpro TarX and Shield Heavy Duty Grade Clay with ONR as lube.
Correction: Carpro Essence / Lake Country Orange Hybrid / Flex 3401
Before
After (excuse the lint from the mf towel - this was cleaned up using Gyeon Prep prior to applying Gyeon Cure)
Before
After
Protection: Gyeon Cure
Glass : Autoglym Fast Glass Cleaner / Wynns C-Thru
Door rubbers, plastic trim : Shield Heavy Duty Vinyl and Rubber Cleaner / Carchem Trim and Tyre Gel
Interior plastics : Shield Heavy Duty Vinyl and Rubber Cleaner / Optimum Optiseal
Interior carpet : Vacuum / Brush / Vacuum
Interior leather : Collinite 855
Exhaust tips: Carchem APC / Mothers Mag and Aluminium Polish / Mothers Powerball
The number plate holders were removed and the old glue residue cleaned off
a
Some pictures of the completed car
And lastly my favorite shot.
Total time spent = 22 hours
As always thanks for looking and any questions or comments are welcome.
:hi:
Awesome write up as always! That turtle wax soap put down some seriously thick foam. Very nice car as well.
Those wheels are gorgeous, nice work man. Definitely some of the best write ups on the forum!
Another beautiful job my friend! Thanks for sharing.
Kyle
Before
After
:hi:
That looks great! I'm just starting out with this and going to buy my polishers in the middle or end of the month. I plan on getting a Megs MT3000 and Griots 3 inch orbital that now accepts 2 inch backing plates. I want to use the Griots on the pillar trim. You did an awesome on them and my question is how you did it.
Thanks very much.
Thanks. Yes it does indeed make rather thick foam. I really don't like the smell of it though, not that it really matters that much in the bigger picture of things.
Nicely done
Thank you
Excellent job !!
Thanks so much
Thank you so much for your kind words - they are much appreciated. I really like the wheels too.
Kyle
Thanks Kyle
Great job as usual! That Carchem APC seems fantastic!
Thank you. It does work well.
Damn! Love your pictures.
Nicely done good sir.
Thanks for sharing.
It's only a pleasure putting these write ups together Mike - I've learned so much from this forum and hope that someone, somewhere, may learn from reading through one of my write ups.
Thanks very much.
Thanks. I used a Flex 3401 fitted with the 4" bp and firstly, a 5" Lake Country Hybrid orange pad and some Menzerna PF2300 followed by a " Lake Country Hybrid white pad and Carpro Essence.
Great work, pics, and write up!!!
Thanks so much Scott
Looks great man!
Thanks so much Dan
