CEE DOG
- Jul 12, 2009
- 7,358
It is possible I screwed up the dilution. I have to check if my pail is 3 gallon or 5 gallon, I filled it up halfway and used 4 bottle caps per gallon as instructed (thinking I was using about 2 gallons of water). The Meguiars gold class shampoo is supposed to be ok: http://www.autogeekonline.net/forum...t-good-inexpensive-car-wash-soap-shampoo.html
I did use about 2-3 coats of opti-seal. The combo of all 3 should be darn protective.
I now have some Optimum Waterless Wash, which I will use going forward.
However, I do have to re-seal the car. It looks like the Wolfgand Glaze is the best, but I need a garage to remove the swirls and a garage for 12 hours to let the glaze cure, which I may or may not be able to get. I don't have a garage in my house. This is why I was thinking about the Klasse AIO, it would take out some swirls, and I hope it cures faster.
Wolfgang finishing Glaze is a finishing polish. You may be referring to Wolfgang Sealant. You already have the Optimum quality products... I would give it another go if even on just one small test spot before giving up on it. Something had to be wrong in the prep, application, or environment. If you're determined to be done with it then the WG sealant is a terrific product.
