Whether you need to chemically strip a surface after using Menzerna or any paint polish is determined by the directions of the LSP you're using.
The word
fillers means different things to different people including the manufacturer.
Keep in mind the entire point of polishing paint is to create beauty. Correct?
A polish company could use
ONLY water for a lubricant but historically, a better lubricant to cushion and buffer the abrading action of the abrasives has been some type of oil. A really bad analogy would be your car's engine. You don't use water for a lubricant you use motor oil.
Here's the point, "YOU" want to create beauty when you machine polish your car's paint so to help "YOU" reach your goal compound and polish manufacturers use some type of lubricating oil in their compound and polish formulas.
These oils can remain on the surface after wiping off the residue and act to make the paint look clear and glossy while at the same time "possibly" masking defects still remaining or defects instilled by the abrasive technology.
And here's the point, some people in our online detailing discussion world will call these lubricating oils fillers. While they may fill, do you think that maybe the reason the compound and polish manufacture used them in their products was to help "YOU" create beauty by buffering the abrasive action of the abrasives?
Just throwing that out there, not directed at anyone but I've been involved with more discussions on fillers in my lifetime than I care for. :laughing:
Bigger point being, any quality compound, polish, pre-wax cleaner, paint cleaner, glaze, and even cleaner/wax is likely going to includes some type of "substance" that lubricates the surface.
If the product you're going to apply as your LSP demands a chemically stripped surface in order for their protection ingredients to properly bond or stick to the surface, then after using ANYONE'S abrading or cleaning product, you're going to need to somehow clean or strip the surface.
Make sense?
I see that Klasse AIO works which I didn't know. I like using CG EZ Creme glaze so I don't have to use an IPA. I just got some CG Black Light and am hoping this will do the same thing as the EZ Creme.
Klasse AIO is a cleaner/wax or more specifically a cleaner/sealant. (Same idea). It's leaving behind it's own layer of "protection ingredients" on the surface and likely has some type of ingredient that lubricates the surface as the product is being worked against it.
Keep in mind, if the manufacturer of a product doesn't state the surface has to be chemically stripped before using "their" protection product then go with it.
Coatings is a different game, that is why I have GTechniq Panel Wipe.
I like Panel Wipe as far as chemical strippers go...
Eraser left my wax applicator pad same color as Eraser, I read this has happened another person. Maybe user error?
Probably the dye in the product staining the "cloth" or "foam" used to make your applicator. Modern clear coat paints, especially when brand new are very impermeable, or non-porous. I would not be worried about dying my clear coat blue especially since you're basically wiping it on and wiping it off. Keep in mind also the MICROfiber as in miniaturized fibers that make of a microfiber towel have the ability to both absorb and adsorb and do a really good job of removing "substances" off a surface. (that's the idea and one of the key benefits over other larger size fiber cloths).
Synergy products: easy, no need to wipe M205 (only to check progress) if using Meg's Ult. Wax and same for Optimum polishes and their LSP, keep it within the family.
In my how-to book and on forums for years I call this a,
Synergistic Chemical Compatibility
Dawn soap: doesn't it have something to make it sheet water off the dishes? Maybe good for a not well maintained vehicle and time to give it a good clean and start with clean slate.
I think that's Cascade for dishwashers? I remember the ad and asked a chemist how a product like this would work and he said instead of the soap and water elements leaving spots on your glasses and dishes it leaves an entire coating or and entire all-covering spot. (This was years ago I asked this question)
:laughing:
