Thank you sir.
I'd say for most people, applying a ceramic paint coating to a brand new vehicle is a good way to go. That said, don't think that a coating is an invisible force field, you must still wash the car carefully and that means besides buying a coating, make sure you have all the right equipment to carefully wash and dry your coated truck.
For example, spend a few bucks and get 1 or 2 Werner Work Platforms. 2 are best for SUVs so you don't have to pick and move the platform each time you move to the other side of the car.
Work Stands Save Time
Werner Aluminum Work Stands are necessary anytime you're washing tall vehicles like SUVs. It's faster to have two one on each side instead of moving a single stand back and forth. Again, doing profitable production work is about saving time not wasting time.
The above is from my article here,
High quality production detailing by Mike Phillips
And then get all the tools you'll need to wash your truck carefully. Check out my article here,
How to wash a coated car - The Gentle Approach for Washing a Car by Mike Phillips
Also - if your budget allows, in my opinion, one of the best investments you can make if you're going to be the "Car Washer in Chief" is to get a Grit Guard Universal Detailing Cart like you see in this picture,
It holds the bucket at waist height so you don't have to bend over every time you need to use your wash mitt. It also holds all your car washing tools and you can roll it around the car as you work around the car.
I have a full write-up coming for this cart in the near future.
The above white Mercedes-Benz picture taken from this article,
Review: GTechniq W6 Iron and General Fallout Remover & W4 Citrus Foam - Mike Phillips
Two comments...
I'm a fan of applying a coating once a year instead of trying to get 2, 3, 4 and so on years out of a single coating application. Mostly because if a car/truck/suv is a
DAILY DRIVER the paint IS going to get a film of dirt on it called road film. (plus other contamination).
This means if you want to re-coat your vehicle you are going to want to do at least one machine polishing step to the paint and then chemically strip the paint. Just keep that in mind. Thus, stick with the 30 ml and leave the 50 ml to pro detailers going through their liquids as a normal practice.
