Review: GYEON Q2 ONE Enthusiast Ceramic Coating by Mike Phillips
First my review
This is a great product. Although it's targeted at first time coating users in my opinion it's a perfect coating for anyone. Why? Because I'm in the camp that for most people, driving daily drivers, you don't want a 2, 3, 4, 5, 6, 7, 8, 9 year or infinity coating because even with a coating, your car because it's exposed to the elements and wear-n-tear, should really be re-polished and then re-coated once a year to maintain both maximum protection and maximum gloss and beauty. I knows this because I've polished coated cars and I've seen the embedded dirt film called road grime come off the car and onto my pad. So call it a once a year coating or an enthusiast coating, it's really a great choice for anyone wanting to protect their daily driver. If you have a garage queen... then sure go for the 2, 3, 4 and so-on coatings advertised to last for multiple years because the paint on garage queens does't see the elements or the wear-n-tear like daily drivers.
Application
Coatings are NOT like traditional car waxes and synthetic sealants. First unlike a car wax or synthetic sealant, there is one extra step required of you to do to the paint on your car before you can apply the coating and that is to chemically strip the paint. I'll show you how below.
Also, coatings take a little more effort to apply. They don't tend to glide over paint like waxes and sealants and this isn't a big deal as long as you're aware of this (and now that you're reading my review you are "aware"), and here's my very simple tip and technique to make applying any coating easier. Slow-down. That's right, don't try to push the applicator over the paint quickly like you can with waxes and sealants. Simply slow down and allow the applicator and the coating to spread over the paint at a speed you can feel through your sense of touch that makes the movement feel easy, not forced. This means allowing a tick more time to apply a coating to your car than you would allow for applying a traditional car wax or synthetic paint sealant. The benefits are worth it.
What are the benefits of a ceramic paint coating?
Extreme gloss - So much gloss that the word I use to describe the appearance is glassy. Glassy is a tick higher than glossy.
Extreme durability - Correctly applied, coatings simply don't wear off like car waxes and synthetic paint sealants. Of course, it is important to still wash a coated care carefully and I have an article on that and will share it later in this thread.
Better protection - Hey if it's lasting longer on the car obviously it's protecting longer.
Faster washing - Ceramic coatings create a hydrophobic or water-fearing surface - water naturally wants to get away from a ceramic coated surface thus washing is faster as dirt is released easier and faster when washing.
Faster drying - Same reasons a ceramic coated car is faster to wash, water wants to get off the car so it will naturally blow off or wipe off.
Self-cleaning effect - Because of the hydrophobic surface, when it rains the water will run off faster and easier and take any accumulated dirt with it.
GYEON Q2 One Enthusiast Ceramic Coating
This new coating is targeted at you if you're still using car waxes and synthetic paint sealants. I'll show you below how to apply it. It's not hard as long as you follow the directions and once you've coated your car you'll have all the experience you need to tackler future coating projects.
This new coating is as easy as it gets when it comes to applying and wiping off the coating. Professional grade coatings can last longer because there is a higher concentration of "solids" in the formula. It is this higher concentration of solids that also makes it more difficult to wipe-off. The solvents used to hold the coating in a liquid emulsion can vary greatly, and this will also have a major influence on how easy or how difficult a coating is to wipe-off. GYEON has taken all these things into consideration and created the perfect balance of a super high quality coating that is easy for the novice to install.
Install
When I hear the word install I think of having new tires installed on my car or having a new stereo installed in my car. The word install is the new term for the word apply. So when you hear or read about someone installing a coating all that means is they are wiping it on and then wiping it off. There is no mystery around the word install, it's just the latest detailing slang for the word apply and wipe-off. :laughing:
Now let's take a look at how to install the GYEON Q2 One Enthusiast Ceramic Coating
Requirements to install a coating
The key thing is the paint needs to be clean as in any above surface bonded contaminants removed as well as any road grime or road film that is impacted onto the paint. Normal washing will not remove above surface contaminants or road film. To remove above surface bonded contaminants you need to use detailing clay or tools like the Nanoskin towels, mitts or pads. Washing will also not remove embedded and impacted road film. To remove road film you need to use one of the below or a combination of the below.
  1. Paint Prep Polish
  2. True Paint Cleaner
  3. Polish
  4. Compound
If you are unsure of what any of the above are please reply to this thread and ask me and I will explain. Or call our customer care hotline and our friendly staff can answer all your car care questions 1-800-869-3011
The BIG PICTURE is you want the paint to be smooth and clean or free from any substance that is not the paint.
Chemically stripping the paint
Assuming you have already reached the point where the paint is clean and smooth, now it's time to chemically strip the paint. What does this mean? In simple terms you're going to use a mild solvent to wipe the paint surface to remove any foreign substance. The best example for what this is abll about is say for example as a part of the process of prepping the paint you used 2, 3, or 4 of the listed ways to prep paint above. A paint cleaner, polish or compound will tend to leave oily residues on the paint even after wiping with a microfiber towel. These oily residues will HINDER the coating from making a proper bond. So the idea behind chemically stripping the paint is to dissolve and remove any substance that could hinder the bonding of the coating to the paint.
This is the extra step that is required for use when installing coatings that is not required when using a traditional car wax or synthetic paint sealant.
GYEON Prep
This is a very safe solvent that works great and unlike some options smells good too...
LOTS OF CLEAN SOFT MICRFOBER TOWELS
Note how I used all capital letters for the heading for this section? That's to stress how important it is to have lots of high quality, clean and soft microfiber towels. You see, clearcoat paints are scratch-sensitive, this means THEY SCRATCH EASILY. Now follow me... it takes HOURS to buff out a car to perfection. It takes SECONDS to put swirls and scratches into a clearcoat paint finish. Guess where most swirls and scratches come from? Dirty, contaminated towels.
My strong recommendation
If you're going to invest the time and money into putting a ceramic paint coating on your car's finish then plan for and budget for a generous amount of DEDICATED microfiber towels JUST for this process. I cannot speak highly enough about the Bald Wipes from GYEON. These towels, unlike most towels have a flat weave instead of a fluffy fiber nap. They are SO LESS LIKELY to become contaminated due to the flat weave. This takes a LOT of the risk out of using them the first time and then using them over and over again because they simply hard to contaminate.
What do I mean by contaminate?
I mean fluffy microfiber towels, it's very easy for any type or form of abrasive particle to embed into the fluffy nap. Not so with a flat weave. Inspecting the towels is faster too and this speeds up all paint related processes. If you don't know how to inspect a microfiber towel or why, read my article here and watch the video.
How, why & when to inspect your microfiber towels when detailing cars
Remember - takes HOURS to remove the swirls and scratches and only SECONDS to put them in... so clean towels are key.
Lots of them...
The last thing you want to do is start a detailing project and run out of trusted towels. So my recommendation is to get 6 Bald Wipes minimum and if your budget allows, get 12. Why 12? Because then you can make a dedicated small wash load washing ONLY these 12 towels. Then dry them together and then store them together. Look at them as tools or as a "tool investment". Take my word for it... towels are your best friend if you're don't want to put swirls and scratches into your car's scratch-sensitive clearcoat finish. (this applies to wash mitts and drying towels too, basically anything that touches the paint).
12 packs of GYEON Bald Wipes
How to chemically strip your car's paint
I know for some, this can sound horrible, that is chemically stripping your car's paint. It's something about the words, chemically stripping. But have no fear, we're not using Aircraft Qualtiy Paint Stripper, a product designed to melt and dissolve paint right off a car. We're talking about a product formulated by GYEON specifically to carefully remove trace polishing oils. It's really not that bad.
First gather your supplies, GYEON Prep and lots of GYEON Bald Wipes
Mike's Method --> Wet Pass followed by Insurance Pass
This is my method, you can come up with your own if you don't like mine. I wipe a car down twice.
The first pass is a very wet pass to remove 98% of any trace oils or other substances. This is called the Wet Pass.
After wiping down the entire car I then wipe the car a second time only I dramatically reduce the amount of Prep I use, this is a moist paint I call the Insurance Pass. This second pass insures I have thoroughly removed any and all trace residues.
How to begin....
Start by spraying a heavy saturation of the prep directly onto the paint. (note I'm wearing nitrile gloves for this step)
Spray enough to see beads of product on the surface.
You should spray enough that the product almost starts to run off like you see in the picture below. IF it's running off that's a tick too much, aim for just before running off.
Me spraying Prep onto the hood...
Me spraying a mist or two onto a clean, folded 4-ways Bald Wipe. Then wipe down a section of a large panel like the hood. Sorry no pictures, but my camera broke, use good technique by spreading the product out and then wiping the product off.
Below is what the towel looks like after wiping just the hood on this Ford Escape. I've unfolded it to show you how wet it looks after one section.
Question: Now think about it... besides the Prep... what else is on this section?
Answer: Oily residues.
So think about it some more... do you want to wipe the next section with this portion of the towel? The answer is "no". If you do you risk removing oils from the next section but also leaving oils on the next section. This is called,
Cross-contamination
You want to avoid cross-contamination. This is why you need lots of towels for the chemical stripping step.
Make sense?
Now I've refolded the towel and while this portion of the towel is wet with Prep, it is still clean as it has not been used to wipe paint. Continue moving around the car spraying sections or panels of paint with Prep and then using clean sides of your Bald Wipes to wipe off oily residues.
Note how I hold my towels?
I fold them 4-ways and then CLAMP the open edges shut using my thumb on one side and my 4 fingers on the other side. This is called
Clamping a towel
Here's another picture showing how much Prep I spray for the first or initial wipe. I sprayed enough onto the front fender that here were plenty of beads of Prep and it just started to form together to run or stream off the fender.
Continue the above until you have wiped down the entire car. Normally you start at the top and work your way down. For pictures for this article I started on the hood and after getting some pictures moved to the roof.
BONUS - Here are some pictures that show what you're trying to do...
This first one is a section of the roof that I have sprayed with the Prep. Note the way the light looks on the paint in the front, right hand corner of the picture?
Here I've cropped out the above section. See where it looks kind of mottled?
What you're seeing is trace residues of oils from the polishing step. Sure I wiped the entire car down but trace oil residues are CLEAR - you cannot see them until you do something to make them show up. In this case I could see them AFTER spraying the paint with the Prep and instead of simply wiping them off I got my cell phone and took these pictures to hopefully enlighten you or to use a bad pun... clear things up. :)
The Insurance Pass
Fro the second wipe or the Insurance Pass, simply MIST some Prep onto a clean, folded Bald Wipe and use this slightly damped side of the towel to re-wipe a panel. After wiping one panel, flip or fold to a clean side and repeat until you've made this second pass to the entire vehicle. Don't spray Prep directly onto the panel, you'll get overspray mist onto finished panels.
Sorry no pictures of me doing the Insurance Pass, no one around to take the picture. Use your imagination. :)
Dirty wet towels
I used 3 Bald Wipes for the Wet Pass and 2 Bald Wipes for the Insurance Pass.
You can visibly see how wet these towels became doing the wet pass.
And you can visibly see how lightly dampened these towels become doing the Insurance Pass.
And here's how much Prep I used to chemically strip a 2014 Ford Escape Sports Utility Vehicle.
This is the level in the bottle before I started...
And here's the Ford Escape after chemically stripping.
Before getting to this point I will note that I started this project by washing this car, then claying, then compounding. So the paint was very clean and smooth before the chemical stripping step.
Continued....
Applying the coating
This is the fun part! This is the 30ml kit and it comes with everything you nee except nitrile gloves to install the GYEON Q2 One to your car's finish.
New for 2018 are frosted glass bottles instead of clear glass bottles. Nice touch, makes it easier to photograph.
Common Sense
With all the cool features that you get with a ceramic paint coating it's important to wear protective gloves. I don't know what it is in the chemical make-up of a ceramic paint coating that makes it last so long and look so glassy but I don know...
I don't want it on my skin...
Foam blocks and suede patches
Most coatings are applied like I'm going to show you. The kit comes with a foam block, one side has a thin soft foam layer, this is the down side as the soft foam will compress to follow curves in the body panel. You take and fold the suede patch of cloth around the block and then use this to apply the coating.
Apply coating directly to the face of the suede patch
After folding the suede patch of cloth around the foam block then dab some coating onto the face of the suede patch. I know most people say apply a few drops but I prefer a wetter applications as it makes it easier to move the block over the paint and it makes it easier for me and thus faster for me to see the layer I'm laying down. You only need a thin film on the surface so adjust the volume of product you use to suit your taste and technique.
Technique
Everyone has to find their own technique as far as holding this suede cloths wrapped around the foam block. I find the nitrile gloves actually help me to grip the suede-wrapped block.
Pattern
When applying a coating, normal protocol is to use a crosshatch patter, that is move the block from front to back and then from side to side,
These two diagrams show the pattern...
The Big Picture
There is NO MYSTERY behind why you move the applicator block in this pattern EXCEPT to ensure UNIFORM COVERAGE over an entire panel or section of a panel. That's it. If you think you can create uniform coverage using a circle motion or ANY other pattern for applying a coating then go for it. The crosshatch pattern is a universal easy to duplicate pattern that anyone can master.
Goal
When applying a coating, the goal is to work the product over and into the paint (as much as is possible as clearcoats are impermeable), until you basically see the product disappear. I find it's easy to make the product disappear in the middle of panels but around the outer edges where I usually lift off the foam block I always leave a high spot or smudge. Underusing the product makes it easier to apply until it visibly disappears. It also makes it more difficult to see a film being deposited. Somewhere in the middle of too little and too much product is the sweet spot you're aiming for and with practice you'll fine tune your application or installation process. :)
Questions
1: How many times to do the crosshatch pattern over a panel or section of a panel?
4 times is a good rule of thumb.
2: How large of a section do you apply to?
Small sections. I broke this hood into 3 sections, the middle and outside sections as Naturally broke up by the raised body lines. I applied to the entire hood, one section at a time.
3: How long to you let the coating sit on the surface before wiping it off?
A minute or less. Basically, after applying to a panel I would set the block and the bottle of coating down and then grab a clean Bald Wipe and wipe the panel clear and free from any coating residue.
Tip: Start by removing the excess coating where you first started to apply it and then follow your path of travel.
Here's the hood with a thin film of GYEON Q2 One Ceramic Paint Coating
High Spots
When I first heard the term high spot I wondered what the heck they were talking about? As a word-guy, (I have 5 published books so I guess I'm a write and thus a word-guy), I would have used one of these words or terms.
  1. Streak
  2. Smear
  3. Excess residue
But once the Genie is out of the bottle it's impossible to put him back in.
The term high spot simply means excess product. It will look like a streak or smear. No problem... simply wipe this high spot carefully to remove the excess product. With this enthusiast level product this is easy to do as the product is very forgiving. With some pro-grade products, the difficulty increases especially if not remove fast enough as the solids that are the coating will start to cure and solidify onto the paint. It's very important to remove the high spots, don't ask me how I know. :)
Through the magic of photography, using the overhead lights, here are some high spots or in common lingo, smears of coating...
Lots of towels...
Remember I said you want to have LOTS of clean, Bald Wipes on hand? Yep. You're going to need them and want them, that's two things.
Take a clean, Bald Wipe and fold 4-ways. The carefully wipe each panel to a clear, high shine. Use overhead and any surrounding lights and look at each panel from multiple angles to locate high spots and then gently wipe them off. Turn to a clean side often for the final buff.
Below this towel is the high spot I pictures above and with a gentle wipe it's gone.
High spot on the other side of the hood
Kind of hard to see in this picture but there's high spot or smear of product in the corner back by the wiper arms.
There's lines going back and forth from where I made my side-to-side wipes...
I've placed some lines next to them to show you the direction of the smears or high spots... There's lots but my cell phone had a hard time picking them up.
No problem - just like a wax smear, simply wipe the area gently and remove the high spots.
In this shot you can see the hazy looking high spot...
And BOOM! Super clear, super glassy looking paint.
The key to removal is simply to take your time and use surrounding light to see and then remove any high spots.
Continued...
Here's the final results....
Note the GLASSY LOOK!
Final comments
If you're new to ceramic paint coatings, this new offering from GYEON is a great way to get your feet wet. It won't break the bank and it's user-friendly. If you want protection that lasts longer, makes washing and drying faster and easier and makes the paint on your car look dripping wet... then you want a ceramic paint coating.
On Autogeek.com
GYEON Q2 ONE 30 ml. - Enthusiast Ceramic Coating
GYEON Q2 One 50 ml. - Enthusiast Ceramic Coating
One of my favorite products for chemically stripping paint...
GYEON Q2M Prep - 500 ml
GYEON Q2M Prep - 1 Liter
GYEON Q2M Prep - 4 Liter
One of my top 5 microfiber towels, might even be number 1 or 2 (I'll have to think about it)
GYEON Bald Wipe Microfiber Towel 16x16
Strong recommendation
When you order your GYEON Bald Wipe towels, tell our customer care staff you read this article and let them know I recommend getting at least a 6 pack and even better, get a dozen. Once you start using these towels you're going to love them. I'll share the link to a future article that explains why.
All GYEON PRODUCTS
Orange Heavy Duty Nitrile Gloves
Remember,
If it's on your skin it's in you -Renny Doyle
By the box
Medium Orange Heavy Duty Nitrile Gloves - Box of 100
Large Orange Heavy Duty Nitrile Gloves - Box of 100
X Large Orange Heavy Duty Nitrile Gloves - Box of 100
XX Large Orange Heavy Duty Nitrile Gloves - Box of 100
By the case
Medium Orange Heavy Duty Nitrile Gloves - Case of 10 = 1000 gloves
Large Orange Heavy Duty Nitrile Gloves - Case of 10 = 1000 gloves
X Large Orange Heavy Duty Nitrile Gloves - Case of 10 = 1000 gloves
XX Large Orange Heavy Duty Nitrile Gloves - Case of 10 = 1000 gloves
Great detailed write up Mike. The coating looks like a winner.
The little SUV looks great. Did you polish after compounding based on your Facebook live videos?
Very nicely written. Your time to document the process and explain to all levels of people trying this is much appreciated.
Man Mike, another incredibly thorough review. I learn something (more like several things) from each one of your reviews/how-to's, even when it is related to something I have already done like applying a coating. Once again...
:urtheman:
Thanks Mike. I may be the first person that has used the written word to explain what "high spots" are?
For what it's worth, my trusty dusty Canon Rebel T5i broke half way through this project. What this means is those "after" shots? Those were taken with my iPhone 6+, not my normal camera. New camera on the way. :)
Owner loves it. That's what's most important.
Great questions, (my Facebook Live videos have seen HUGE hits by the way).
The answer is "no". I compounded with the white LC Hybrid pads and the FLEX 3401 on speed 5 and then stuck a fork in it and called it done. I truly found the paint on this Ford to be on the hard side. She didn't have a lot of swirl and scratches to start with, the owner takes care to wash and dry carefully, remember your car's paint looks comes down to how >you< (or someone else), TOUCHES it. It all comes down to the touching.
I tested this compound out at SEMA and was very impressed with the abrasive technology. I did a Test Spot on the hood and after wipe-off and then chemically stripping the test spot had had the confidence to ONLY compound the paint and it was a quick compound, mostly to remove road film and minor or shallow swirls and scratches.
I need to find a totally swirled out car like the last to 1970 Chevelles I detailed to really put this compound to the test. I have 9 classes I have to prep for as Mobile Tech Expos is about 2+ weeks away. Then I have my 2-day boat class and right after that my 3-day class.
Point being... time is limited and I have a ton of prep work to do. So as soon as I can carve out the time I will do a more thorough test of the new Compound +. I do have a review for it that I'll post next week.
Thank you for reading and your follow-up questions.
Love the Gyeon BaldWipe and PolishWipe towels. Usually prefer the BaldWipe for Prep wipedown and initial pass on coating removal, followed by 2nd buffing/wipedown pass on section with PolishWipe. The one caveat wirh the Gyeon towels is they seem to bleed blue during washing for a relatively long time so now I try to wash separate.
Curious as to where you stand on the 'Throw away any towels used to remove coating after use'; that can get a bit costly if addicted to the Gyeon towels.
Gyeon really revamped their coating lineup this year; gonna be interesting to give 'em all a try; their products are generally always 'good stuff'
Initially i found the microsuede/block a bit inconvenient insofar as setting down, 'readjusting' cloth when picking up; saw/read somewhere using by cutting a shallow slit longitudinally down side of block, wrap cloth and tuck into slits and it stays pretty nicely.
Interesting stuff for sure.
Great write up and you write so we understand it. Many write as you are an experienced user. And accually it's the companys who creates them and their descriptions left out many things. As when you buy a coating kit. They don't write that you need more applicator towels and wipe of towels than you get. You would think 4 applicator towels and a wipe of towel is enough. But when you read about experienced user apply the coating they use alot of towels.
Is the towels enough to apply a coating that follow the coating kit in your opinion?
Thanks for the detailed write up!
Tony
I think you are right about covering the term high spots. Also those are great results on the compound alone. It left a great finish on that hard paint.
That's a great write-up, Mike. As always, you offer great new & alternative perspectives for newcomers and experienced detailers alike, and I do think your coverage of the high spots is a great one. I'm glad someone else seems to use a lot of prep solution as well; I tend to use less Gtechniq Panel Wipe though. IMHO it takes less than IPA or Gyeon Prep.
BudgetPlan1:
Not sure you have to throw them away if you're using those flat weave ones. However, I tend to use them only for coating vehicles. Throwing them away would get expensive. (At least you should downgrade them if you do want to toss them!) I realize the fear is instilling swirls and scratches into the paint since, theoretically, they have SiO2 (glass!) in them now. It hasn't been so much my experience when tossing them directly into some water/APC after using them.
I am moving towards Gtechniq PW as well, previously a Gyeon Prep user. Seems as if Gtechniq cleans better and quicker, less wiping needed. Seems to work best in smaller sections than Prep but still an overall time saver and, to me, better results.
I generally toss immediately in bucket of water/APC as well, then launder when done...Good towels ain't cheap.
I did miss a towel I used to apply/buff CanCoat recently. Found a couple of days later and it was toast for sure. Oops.
I've missed them for sure! They end up repelling all water it seems!
(Sent via my mobile device...)
Thanks for sharing Mike. I always learn something new with your reviews
That's a good process for towel choice. One thing I like about flat weave towels is the zero no low linting issue. And when working with coatings, for both the prep step and the wipe-off step, the last thing you want to deal with is linting. Especially if you're working on black or other dark colors. The Bald Wipes solve this issue.
Meguiar's also has a flat weave towel in their Professional Line, the M9910. Even though stains in towels are a non-issue as far as performance goes, (in my experience), the Meguiar's M9910 is white and shows stains while the GYEON Bald Wipe being purple is simply less prone to showcasing stains. But again... a non-issue.
While bleeding or fading is going to be normal with any cloth that's dyed, (even my jeans fade), it's a good practice to wash separately. I have an upcoming article on this topic... hang tight...
Not me. I wash and re-use. If a person wants to be super careful, then simply mix up 2-3 gallons of water and some microfiber detergent and immediately after using a towel, place into the bucket and squish around and let your towels soak until the project is over and then immediately wash as soon as you are possible. Keeping them wet an away from air plus the detergent doing it's thing should help reduce any coating permanently contaminating a towel. I know for mobile guys, this will require an extra step but if you get one of the 5-gallon buckets we sell with the Gamma-Seal lid, you can include this in your normal detailing processes.
I agree. I would consider GYEON coatings a top shelf product line.
Initially i found the microsuede/block a bit inconvenient insofar as setting down, 'read justing' cloth when picking up; saw/read somewhere using by cutting a shallow slit longitudinally down side of block, wrap cloth and tuck into slits and it stays pretty nicely.
I'm not a huge fan of applying coatings with suede-wrapped blocks, it's simply awkward and cumbersome. But at this point it does make the process cost-effective.
What you don't want to do is use any type of applicator that is THICK and will soak up a LOT of the [in most cases] expensive coating. Thus the way most of the coating application blocks on the market are designed are to have a rigid block of foam that does NOT absorb to give the user something to hold on to and then an thin layer of absorbing foam not used so much to absorb but to conform to curves and then the soft suede patch of microfiber to be the contact medium that spreads the coating over scratch-sensitive paint.
Thanks for the great review, Mike! Gyeon products have really caught my eye this Winter.
After reading through this, I'm starting to realize I'm probably using far to little product during the prep stage. Coating longevity doesn't seem to be degraded, but I'm sure it would make the oil remover much easier and effective.
Thanks for the tips Mike.
I have not used enough of the panel wipe products before coating when compared to your tutorial. Also, I have not been doing a total of 4 crosshatch passes when applying a coating. I will be implementing both of your processes on my next coating application!
One remaining question I have is there an ideal temperature when to apply a coating or is there a temperature range where you would not apply a coating? It is winter time now so I am always wondering if it is too cold to apply a coating.
While I was aware of the Mohs & Booster combo approximating their Durabead Pro-Only product, Gyeon offered up the following regarding their other pro-coatings. Was always kinda iffy on the differences in specific characteristics between the pro stuff and what I could approximate via their consumer line.
Gyeon Pro Coatings:
Mohs+ - No consumer approximation I could find
Durabead - Consumer version approximation is Mohs + Booster (reactive top coat, flourine based)
Duraflex - Consumer version approximation is new Syncro
The have a few similarities:
- all are 2 ingredient/stage coatings;
- all come with the same durability
- all come with 5 year limited warranties
What makes them different is the application and mostly the characteristics of the top coat (2nd ingredient).
In Mohs+, the Phobic top coat is a ceramic coating, being the least hydrophobic, but probably the most glossy of them all.
Bead, the DuraBead top coat, is a reactive, fluorine-based product, which is in fact not another layer added on top, but something that changes the properties of the previously applied Mohs, extending durability and adding great hydrophobicity
DuraFlex it the most modern of them all, providing great slickness, superb hydrophobicity and high thickness with just 2 layers.
Thanks for sharing the GYEON info... :dblthumb2:
I like to think of things from the BIG PICTURE point of view when it comes to car detailing although I know many in our industry/hobby are very detailed or anal retentive when it comes to all things detailing. That said, my experience is that any car that is a daily driver, parked outside most of the time, the paint will get a dirt film on it that is impacted or bonded to the surface - no matter what the surface is and this includes coatings.
Not a big deal if a person is only talking about protection and durability - but as soon as appearance is brought into the mix, then I'm a firm believer that nothing looks as good as a freshly coated car. So after one year goes by for a daily driver, this car would benefit from a light polishing and re-application of a coating to restore that just-coated-look.
So in my mind, coatings that last longer than a year are great but for anyone that has the ability to re-polish their car, then a one year coating is more than enough and at any point along the way when you wash and dry your car and it is no longer as crisp and glassy looking as it was the day you made the final wipe after installing the previous coating - then go for it, re-polish and recoat and then stand back and admire the intense gloss and shine.
