Review: Ultima Interior Guard Plus (UIGP)
CEE DOG
Introduction:
I have been a huge fan of Ultima products since my first experience with UPGP. For my tastes Ultima products offer some of the best products I’ve tried in looks, durability, and ease of use. I’ve been using 303 AP as an interior protectant for a long time and I love it. I’ve also used 1Z and Lexol brands for the leather. Anyway a couple weeks ago I finally coughed up the dough to try out the Ultima Interior Guard Plus (UIGP). Over the Independence Day weekend I spent some time with this wonderful product. Without further ado here is my review.
Product Description (from AG):
Ultima Interior Guard Plus is the first and only polymer sealant for automotive interiors. The Ultima sealant protection lasts for months and requires only a damp cloth or Ultima Detail Spray Plus to clean and maintain. Plus, unlike traditional interior dressings, Ultima Interior Guard Plus maintains an even, natural appearance and will not fog your interior glass.
Initial Product Observations:
1.- Manufacturer Claims: True * (I have not tested UV protection or durability)
2.- Packaging: Large clear plastic cylinder contains a red and gray UIGP sponge applicator and the UIGP contained in a fancy elliptical blue plastic bottle with pump spray nozzle
3.- Directions: The directions on the bottle contradict the directions from my 2009 Ultima user guide I will call Ultima and clear this up. The correct directions will be posted in this review.
4.- Consistency: Thin Liquid Polymer Sealant
5.- Color: Clear
6.- Scent: No fragrance beyond the initial faint chemical smell which you probably won’t notice unless you stick your nose in the bottle
J (Such is the cost of creating a comprehensive review)
7.- Size: 12 oz.
8.- Current Price: $34.99
9.- Manufacturer: Four Star Products (Premium Finish Care)
10.-Made in: USA
Additional products used for prep, during application, or removal:
1.- Microfiber towel
Method of Application, and noted Observations:
This is going to be a little long but I hope you will bear with me. J
I started by cleaning the entire interior with DP interior cleaner. Next I taped off a section of my dashboard, passenger side door, and passenger side leather seat for contrast. Then I gave the bottle a good shake and off to the fun part! I primed the included applicator with one spray and then sprayed once more. Applying UIGP to the leather seat I noticed that initially the finish looked very glossy and oily. As it dried the glossy, oily look faded away. I also found that the applicator shed a couple small particles. Mind you it was only a few but I didn’t like that. This may have been my fault as I found myself initially rubbing harder then I really wanted to. I think this learning curve was associated to my extensive use of Ultima paint sealant with which one spritz lasts close to 3 sq ft. With the UIGP one spray covered a fair bit. However it certainly didn’t cover 3 sq ft. (which makes sense due to the materials) so I was rubbing harder for a moment instead of applying more product as early as I should have. I know with Ultima products less is more so I didn’t want to over saturate the applicator. Proper use dictates after initial priming you should spray once more and then work across surface until you no longer see product coming from applicator. From then on it’s 1 spray and apply. I continued with application across all of the leather, plastic, and vinyl of my interior (Except of course the taped off “contrast areas”). I also coated the plastic interior frame covering of my convertible top, the glossy silver plastic around my shifter, my chrome shifter knob, and the perforated black metal speaker covers. As the bottle directed about half way through the application process I went back and buffed the area I had already completed starting at the beginning. Then finished the last of the interior and buffed that as well.
I was a little confused as I could have sworn this was a wipe on walk away product like the exterior sealant. So, as I was writing this review on Wednesday I was looking at some info about application instructions and saw it said not to dry or buff (just as I had thought was the case). I followed the instructions on the bottle and it came out nice so I had to assume what I was reading on line was incorrect. Still it didn’t seem like I should have to buff it. I remembered that I had an Ultima user guide from last year so I consulted the guide. Well, there it was in the user guide. “Do not buff” “Wipe on and walk away”. I wouldn’t be posting this review Wednesday night after all!
I called Sam Lankford (Owner of Premium Finish Care) this morning and he was extremely courteous and helpful. The following is what he told me. Ultima Interior Guard Plus is designed as a wipe on and walk away product in order to cut your application time in half. If applied correctly (thin) you will not need to dry or buff the product. The reason the label states to buff off after 3-5 minutes is that apparently some people were applying it too thick. If you apply it too thick then you may see some streaking. In this event you can go back and buff that area after 3 minutes. I also asked Sam if waiting until you’re done with the whole car or longer before buffing a streak would matter. He said no problem either way. Sam recommends you apply in a circular motion and then finish in a straight line. During application I hadn’t experienced streaking but I had buffed the area anyway so I also asked Sam if this could have compromised my durability. He said this would not be an issue either. All of his answers were exactly what I wanted to hear. This means application time is really great! Just don’t put it on thick and you’ll be fine. Any streaking can be corrected as needed.
Ok, where were we? Ah yes… I did not seal my mats with UIGP as they are currently guarded with 303 fabric protectant, but I will in the future. For application to fabric or carpet you can spray a light coating directly at the material and then wipe with cloth. I don’t remember if I applied the Sonax and 303 AP to their respective areas before or after the UIGP but it matters not. On the taped off leather seat the pictures to come will show the contrast between UIGP, no dressing, and 303 AP. On the dashboard and door panel the pictures to come will show the contrast between UIGP, no dressing, and Sonax Dashboard Cleaner matte finish.
UIGP can dry in as little as 15 minutes, or take as long as an hour depending on conditions like humidity. (I observed drying time at about 15 minutes). For best results Ultima recommends that you allow the polymers to cure (cross link) overnight. However you can drive the car after an hour. So I pulled the car back into the garage and waited till the next morning to take the pictures and inspect the finish. The next morning everything looked really great! The black leather and vinyl was a richer darker tone but not glossy. The glossy silver plastic as well as the chrome shifter and door handles were very shiny. They had no streaks and were not at all dulled by UIGP. Please see the pictures and rejoin me afterwards to see the listed Pros, Cons, and Summary.
1.- Conditions
2.- Before
3.- N/A
4.- Product
5.- Foam Particle from Applicator
6.- Seconds after application
7.- 50/50 with no dressing on the tape line
8.- 50/50 with no dressing on the tape line
9.- 50/50 with no dressing on the tape line
10.- 33/33/33
11.- UIGP 50/50
12.- 303 AP 50/50
13.- Seats After
14.- Seats After
15.- After
16.- After
17.- After
18.- After
19.- Behind Seat After
20.- Behind Seat After (Lighting made it look gray) It’s Black
21.- Seats After (Being able to drop the top to let the sunshine in is great for reviews too!)
22.- Cockpit After
23.- Plastic above Console (A little out of focus)
24.- Shifter After
25.- Close up Plastic Around Shifter After
26.- Door 50/50 with no dressing on the tape line
27.- Door 50/50 with no dressing on the tape line
28.- Dash 50/50 with no dressing on the tape line
29.- Dash UIGP Close up
30.- Dash 50/50 with no dressing on the tape line
Pros:
1.- Extremely Versatile: use on ALL interior surfaces except glass.
2.- Great Looks: Deepens and enriches the look of the interior while taking on the look of the surface which it is applied to (flat, matte, satin or glossy) Glossy surfaces will be glossy. Matte surfaces will maintain their matte finish, etc.
3.- Feel: Interior is very soft with no greasy or slippery feeling (Especially the leather and smooth plastic components (I can’t stop touching them
J)
4.- Speed of application: Wipe on & Walk away
5.- Ease of cleaning after surfaces are sealed
6.- UV Protection
7.- Resists water and staining as well as the effects of oils and salt from the skin
8.- **Durability: 3+ months (In process of testing this but from what I understand this is accurate)
Cons:
1.- Not so sure I like the included applicator as much as I thought I would. Ultima tips say to stick with that applicator to ensure an even coating however in my conversation with Sam he mentioned using a Microfiber towel. I think I’ll try one of those square Microfiber applicators next time.
2.- See ??? # 2
1.- If it would help more people try it, I would love to see Autogeek stock a 4 oz. size as well as the 12 oz. they already carry.
2.-Price: I moved back and forth on placing this as a con. The initial price was what held me back from trying this product sooner. The truth is now that I’ve tried it I wish I hadn’t waited so long, therefore I can’t list this as a con. I will purchase this product again at this price without hesitation. In the long run the price is actually good thanks to the very small amount of product that is needed for application and the durability aspects.
Final Observations and Summary:
This is a fantastic product that may scare some off with its initial price. However, if purchased I think a lot of you will make this a go to product. Regret is extremely unlikely. I really love this product and I hope you will too. It has become my go to product for protecting my interior. I will update further with some testing on durability. I still look forward to using 303 AP as well as Sonax DC for certain cases and applications. Please let me know if you have any questions or comments. Well, it was 1,868 words. I hope you’re still awake and you enjoyed it J
And the link: Ultima Interior Guard Plus 12 oz., interior protectant, rubber & vinyl protectant, dash dressing
Thanks for the detailed review Corey! :xyxthumbs:
I prefer the "darkening" look of 303.
Now you have me really tempted, but the price is a huge obstacle.
Good job Corey. I've said it before and I'll say it again "Ultima products do not get nearly the recognition they should" I have a 4oz bottle which I believe came from AG awhile back. I really agree with you on the applicator and use the cloth covered applicators. The terry or micro applicators are often on bogo and tend to work well with many products I use.
By the way, How much of that 12 oz bottle did you use? A little goes a long way.
How do you like going from "Slide" to "Glide" when getting in or out of your seats?
Hey Corey, I am with a few of the others here in that the 303 looked better to my eye in your photos.
Are the photos a "true" reflection of what you saw?
Besides the deeper black of the 303, did you notice a difference in the feel between the 303 and UIGP? You mentioned you couldn't stop getting the tactile feedback of the surfaces.
Thanks again for a detailed, concise and informative review. :dblthumb2::dblthumb2:
Wow! Great review! I knew I shoulda bought the 4 oz when it was BOGO. I have about a half gallon of OPP and a qt of 303 so I passed. The price is not bad IMO if it goes half as far as UPGP. You have only Mike P. as a peer for reviews!
My pleasure Mark! The UIGP actually darkens the leather and vinyl some as well but without adding gloss to it. The 303 does darken it a little more but not by the amount the pictures show.
Yea, I like it darker too
:dblthumb2:
Christmas or birthday present maybe?
Agree with both of these even though they conflict each other.
:laughing:
I think that's really expensive..
I would say that it probably costs 25-50 cents a month per vehicle.
$2.91 per ounce
Probably use about 1/4 ounce on a vehicle
That 1/4 ounce lasts about 3 months if durability holds true.
I have to pay closer attention to exactly how many sprays I use next time. Then I can say exactly how much of one ounce it takes to do an interior. Of course interior sizes vary. Even if you quadruple my estimate you are talking about $1.00 a month.
Also bear in mind the time saved by easier cleanings in between. Time is money!
Also if you get 20% off on a sale you can grab it for like $28.
Oh, and the "tactile feel" (thanks mchess1) is priceless
You can call me biased now... :laughing:
Good job Corey. I've said it before and I'll say it again "Ultima products do not get nearly the recognition they should" I really agree with you on the applicator and use the cloth covered applicators. The terry or micro applicators are often on bogo and tend to work well with many products I use.
Thank you Fred! As far as the Ultima recognition you and I are on the exact same page. I completely agree with you. Its very weird isn't it? :)
Glad to hear the mf applicators work great for you. Look forward to using them next time. I've got about 4 of them left over from DF that I haven't used.
I sent a sample out before using this and now I'm kicking myself for not marking the bottle but it looks like it's at the same level now that it was before I used it. I would say 1/4 oz (maybe even less). Certainly no more then 1/2 oz. I am going to measure next time so I can have a factual number.
Well said, you were absolutely right man!! Thanks so much for the recommendation! I love it as much as you do :dblthumb2:
That is a great question:props: In fact the photos do not show an exact representation.
The UIGP actually darkens the leather and vinyl some as well but without adding any gloss to it. The 303 does darken it more but not by the amount the pictures show.
I still love the look of 303 as well but the UIGP has other intangibles that no other brand offers.
Absolutely, the other products do not compare when it comes to the tactile feel of UIGP. The feel of the Ultima is what I meant I couldn't stop touching. When Mrs. CEE got in the car for a ride she commented on it as well. I can't think of a better way to describe it then AutoGeek already did. "Instead, fabrics, leather and vinyl all take on the tactile feel of fine cashmere. You will glide in and out of your leather seating and feel a new comfort that's silky smooth, but not slippery."
Thank you so much! I'm glad you enjoyed it!
Thank you so much! That is quite a compliment! You can always try it out down the road :dblthumb2:
As always Corey, excellent review, and a very enjoyable read. I can't wait to try out mine (thanks)! You are the "Review Master"! Thanks for taking the time to do it for us...
I will get it next order. After spending $250 on the fab 4th blowout I gotta lay low for a few weeks or the next BOGO!
Thanks Tad!! I can't wait to hear your thoughts!
Let me know what you think once you've used it. I'd love to hear you opinion
One other thing I was thinking about. It is going to be best applied on a cool surface out of the sun because of the small amount that is needed. This way you won't force it to dry too fast and you'll have a much better idea of how much you are applying.
I like that it does not darken the interior as much. This might be a great follow up to 1z interior cleaner to get more protection but leave as close to the original finish as possible... this is my goal with most surfaces on the car (except the wheel wells... id like to darken them as much as possible).
Might be a knock out duo I'm gonna have to try out after I get through the Pbs NL dressing i have stocked up
Excellent review. I'm really liking the look of this interior protectant. I'd never even heard of this line before, May have to give it a try after some more research.:xyxthumbs:
Nice review as usual. It sounds like the entire Ultima line is a sealant for every surface.
Based the feedback, some people like natural look and some do not.
Where did you get the red foam applicator?
I actually think the 1Z might not let the UIGP bond correctly decreasing durability.
Thank you. Definitely gotta try it out. I haven't tried the elastofoam thing but I've tried almost everything else and it is all top notch.
Thank you. Ultima really excels at a combination of amazing looks and quick applications.
As with most Ultima products they provide an applicator. The red foam applicator was provided by them contained in this plastci cylinder with black polygonal lid....
.........Minus the ziploc baggie its in now :)
