With the flex "lightweight" should I add a couple hundred RPM's because it's not as "powerful"? I use the recommended size pads(no bigger than 6"), so should it still spin what it says on the speed dial?
Thats getting into a subject Ive been meaning to get into.
With a rotary youre basicly using a rotary "cutter" so to speak and the majority of the "cutting" is being done on the outside diameter of the pad.
The surface speed on the outside diameter is a major factor in determining how "fast" its going to cut assuming the pressure and compound are the same.
Lets start with a big old 8" pad at say 1500 rpm, The outer part of the pad is moving along at almost 38K inches per minute (38000)
Say you drop down to a 7" pad at 1500 , your surface speed will drop down to 33K
To get the surface speed of the 8" pad you would need a little over 1700 rpm
Now pick up the flex with a 6" pad, 1500 rpm will get you a surface speed of 28K; to get 38k (like an 8" pad) you would need a little over 2k rpm.
What Im saying is try to keep "surface speed" in the back of your mind if youre using a rotary. You can certainly put on a smaller diameter pad and dial up the speed a bit.
Also putting on a smaller pad and keeping the RPM within reason can make the rotary buffer a little more "forgiving"
....then you need to max out on pressure first. IF, and only if, that doesn't work for you, crank up the speed. Speed up your passes. You are going to generate a boat load of friction, so be careful. High pressure + high speed= max correction. Don't just jump to that stage. There is most likely a stage at less than the max that will do the job for you.
1500?
While what you're saying is definitely a perfectly valid approach, I would say that lower pressure and higher speed are also effective without being exceedingly unsafe. Friction generated by speed vs. friction created by pressure will likely equal out in terms of cut and also in terms of byproduct heat.
"There are no absolutes in detailing". Quote me on that.
I say it often. Like all approaches to detailing, you always start with a least aggressive approach and amp it up from there.
The first amp up should be more pressure. Push down harder. Push down even harder if that doesn't work. That is increasing the friction yet is still safer than high speed.
I normally try to stay between 1535 and 1547....... then use about 10 lbs of pressure first pass, then each pass I lower the lbs of pressure about 1.5 lbs a pass. Hope this helps :dblthumb2: lol!
I bet this gets picked apart lol
This was a joke by the way..... It depends on industry and opinion on each and every vehicle. I can go 2500 and slower on buses cause the paint is extremely thick..... on cars it is a judgment call but normally stays between 1000 and 1700 - depending on what my internal Paint gage says lol
Internal Paint Gage? When did they start produceing those......gezzzzzzz somebody stole my Idea again!!!!! LOL
