WRAPT C5Z06
- Nov 12, 2009
- 12,615
I currently have a "chinese" 15mm that cost me $120 and it works GREAT!! I use the washer mod. I can get more cut with it using a MF cutting pad than my 3401 with a wool pad. Yes, you have to pay more attention to technique to keep the pad spinning with the 15mm(any non-forced DA), but the cut/finish is just awesome! With the 3401, you could probably get through a detail faster because pad stall is not an issue, but, you will not get as good of cut/finish as a long throw DA. JMO.
