Sanding mark challenge! Jet Black SL63 - OCDetail
Jsmooth
This poor AMG Benz had been seriously violated by someone! Far as I could tell it was DA sanded and wrecked with improper rotary buffing skills... The DA sand marks or "Pig Tails" were so bad the first time I saw the car out in the sun I thought it was metallic blue. I have a lot of respect for the person who tried to detail this if you can call it that... They did not miss a single spot in the sanding attempt, except behind the back plate because like any hack they left it on the car because "if you'll never see it doesn't matter right?". Well these little things should of been a sign of what was to come. Lets get on with it!
See it looks blue lol
Out side after a wash and paint decontamination I was still thinking this wasn't going to be bad Just some buffer swirls to deal with...
Inside using my point lights revealed a new story! HOLY SANDING MARKS BAT MAN! The flat areas were not that bad but the amount of edge work I had to be aggressive with was very trying!
My good friend Jeff of Immaculate reflections popped in for a bit to lend a hand :)
After a few hours he had the trunk deck all compounded. And not to take away from any of my usual help but this car was so hard to work on that the only people that had success was my self and Jeff. Everyone else very much left me "on my own". After this Jeff had to go... something about a perm or highlights.. I guess it takes work to keep immaculate hair.
Use with caution! skipped heavy and went to nuke status with flash pads and a rotary for my initial compounding. This is some serious aggression that is usually only reserved for ex wives..
I spent close to 10 hours on the rear end of this car compounding! No special lights needed to see the difference on this bumper!
Ta Da!
Above done, below... This was so time consuming...
More awesome edge work on a car that had clearly been sanded and violated by aggressive rotary polishing. This wasn't scary at all I promise!
Moving right along. This rear bumper was hours... Hours of compounding..
It was so crushing, every time I finished a section and was happy with it. I'd move my light over and little bit of joy and accomplishment I had would quickly go away. IT seemed to never end!
This went on for days...
I would keep going on the before/after and 50/50 shot but feel free to go look at all 100 pics on my photobucket album here. Ok fast forward a few sleepless nights and cpl more days of this and...
After all my compounding I had to follow it up with a "middle step" and finishing polish step prior to Opti Coat Pro application.
BLING! Seriously this car tried my patients and skills at level I have not experienced since before I was experienced. I was so happy when it was done and it looked GREAT!
Thanks for looking
Joseph Torbati
www.bayareadetails.com
Ta Da!
Thanks for looking
Joseph Torbati
Awesome work! I myself just had a AMG that was killed by the improper use of a rotary unfortunately I didn't have the help though, it was a painful 5 days.
Nice work
Did the Owner confirm that the car had been sanded?
I have actually witnessed 1st hand this type of damage inflicted with a Rupes 21, Compound and a pad that was not totally clean
Some of the damage that was done looked similar to your pictures, but I would characterize most of it as bad tick marks and a few pigtails that had the distinct Rupes long-stroke with a direction change at the end...they look more like a fish hook, than a pig tail from a 8mm DA sander
Wow, one of the best saves I've seen, very well documented.
Thanks a lot for sharing,
Kind Regards.
Thanks guys!
Nice work
And I'm 100% sure it was sanding pig tails. If you look at the album on Photobucket its pretty obvious. I know the marks your talking about, I've done that a time or 2 DOH! And customer bought car with 4k miles on it and wasn't sure. He really thought it was metallic blue.
did you happen to take paint measurements on that car?
why the sanding marks? any guesses???
Nice job dood!! :dblthumb2:
I imagine you removed a good amount of clear by having to compound that much?
Awesome save :dblthumb2:
I am also curious about how much paint was on the car, and how much was removed.
Outstanding work on that Benz's you can gaze at that glossy paintwork for days, and don't bored/tired
Thanks guys and I just moved and had no gauge with me. Its ok though the paint was still hard as nails through my whole process. Anyone who has seen a benz that has had that top layer of ceramic went through KNOWS because it because sneeze and scratch soft.
