Wow that’s a lot of pages. I’ve read about 20 of them. Is there a verdict for best paint sealant?
Just realized I had not replied this. SWETM directed you to the spreadsheet. That's the best way to see the results. I have long-winded response in here somewhere about what is "best." It's really a matter of preference. Most of the products I've tested are quite good. A few don't last long, and some seem very over-priced to me.Wow that’s a lot of pages. I’ve read about 20 of them. Is there a verdict for best paint sealant?
Per DG, yes it can be used with other products. I'm guessing it would work with any polymer based sealant. Would be good to do some side-by-side testing with and without it to see if it helps with longevity. I like using it with DG products because it takes the cure time down to almost nothing. I can get 2 coats of DG 111 applied with no wait time between them. (Although I'm using PNS more than other sealants now.)Great job, Rippy...thanks for all the effort you put into this.rops:
I have a question regarding Duragloss PBA (Polish Bonding Agent). Is this a product that can be used ONLY in conjunction with Duragloss products, or can this be used with other waxes and sealants as well? And if so, are there any boundaries or guidelines as to what it will NOT work with? Thanks
Rover video is blocked for me.
Did you ever score the 2 Essence, gloss and plus?
Be cool to see the plus durability and Essence gloss with some sealant like PNS on it. Or would that be cheating?
This video link should work. Too late to go back and edit that post. (Rant: Google Photo should make this stuff dead simple and foolproof. They don't. It's never obvious which photos/vids are shared or not.)Rover video is blocked for me.
A little hard to answer because I don't entirely trust the hood tests or the products I've tested only once. Not enough runoff on the hood. I'm hoping to get everything re-tested on vertical panels at least twice to validate or correct the results.RippyD which is the most durable spray wax or QD product that you have been testing?
Having said that, here's how I would pick for longevity based on the data:
A bunch of others seem to be in the 3-4 week range, depending on weather. My go-to has been Aquawax because it's cheap and I think it gives a great shine. This could be placebo effect - I haven't done blind testing side-by-side with another spray wax. When my Aquawax is gone I may switch to Future Armour or Opt. I want a spray that I can use as a drying aid.
- 303 Spray Wax looks good for longevity (can't be used as a drying aid)
- Dodo Future Armour is excellent as well
- Opt Spray Wax
- DG 931 as a QD (This should not work this well - I'll keep testing it)
- Reload
- Rupes 808? (Has been inconsistent for me - has to be diluted to use as a drying aid)
- Sonax BSD
