swanicyouth
- Mar 3, 2011
- 9,388
As others have noted, about 400 watts is the AC power consumption. All that tells you is that you can safely run it on a 15 amp circuit simultaneously with another tool consuming about 9 amps.
That number doesn't have a direct relationship with the correcting power at the pad, especially with a free-rotating type of DA where the pad rotation can be stopped to zero rotations while the machine's motor is consuming the full rated power from the AC line, in driving the oscillating portion (where the OPM is applicable) of the dual action.
see this link for specs:
Check Out The New Rupes LHR 75E Mini & Rupes LHR 12E Duetto [SEMA Show 2013] | Ask a Pro Blog
I know W=VxA. Watts is the power used and Amperes is the amount of electrons that moves through a circuit in a certain period of time. I'm not an electrician.
That being said, in the real world it does have SOME relationship to how powerful or how "ballsy" a machine is. Most of the DA machines have motors and overall designs that are relatively similarly efficient. Sure there are a ton of other factors, but GENERALLY a machine that draws significantly more power will be more powerful.
For example, a GG6 is 7.5 amps and 850 watts. That's significantly more powerful than a 7424 that's like 4 amps and 500 watts (or around that if I recall). Its a power difference you can feel. Sure the motors and machines are different, the efficiency of each isn't 100% equal - but I think its safe to assume your basically comparing apples to apples - and watts and amps give you a ballpark of the more powerful machine.
When I'm talking about the motors power output, I'm talking about its ability to spin the pad under conditions that are not perfect (complex/concave panels) and not bog down. I know their isn't a direct rotary like connection from the motor to the spindle, but generally speaking, I believe there is SOMEWHAT of a direct relationship between the power these DA machines consume and the power they put out.
I do believe a larger stroke machine corrects better than a smaller one. However, I don't believe that a larger stroke machine whose pad isn't spinning corrects BETTER than a smaller stroke machine whose pad is spinning well (just jiggling).
All my opinions and my experience. So, I do believe input amperes and watts does have some bearing on the correction ability of a machine.
