Silly Rabbit
Active member
- Apr 29, 2021
- 676
- 104
What about Koch Chemie Motorplast?? Anyone use that??
Sonus Trim & Motor Kote, acrylic protectant, black plastic protectant, engine dressing
After you clean the engine and it is DRY, spray a few pumps of the sonus. You don't have to go crazy. DO NOT WIPE OR TOUCH IT. End result is a protective coating with just the right look. Perfect results each and every time.
Found my write up on it when i owned my Xterra...
https://www.autogeekonline.net/foru...ighlight=what+can+sonus+moter+kote+do+for+you
Once a week on thd old man's ute, but i vacuum the engine bay call me CRAZY i am but nothing beats the feeling when the post man catches you in the process and says What the hell are you doing?
Megs HD is another way to do it. Being water based it just will not last as long. HD is great for dressing plastic wheel wells also. The beauty of HD is that can be sprayed on a WET surface and just left alone to dry. It levels out and dries to a nice satin finish. NO WIPING OR TOUCHING. So after your engine is cleaned, you would just spray HD all over the engine bay and walk away. You don't have to dry the engine before using it. I used it 4:1 when i was doing wheel wells and engines. And being WB, it is SAFE for all under hood areas. Switched to Sonus for better durability.
...i vacuum the engine bay call me CRAZY...
After reading this thread I tried 2:1 303 on a customers engine bay using a spray bottle.
Turned out great, but the mistake I made was not applying it immediately after cleaning the bay.
On jobs where the engine is to be done, it’s always done first, before the wash. Well, after cleaning the engine I normally let the vehicle idle while I blow it dry, then close the hood and allow the engine heat to dry it completely while I get things ready for the wash. I then turn the engine off, perform the wash, and apply trim shine with a flag tip brush.
Instead I sprayed 303 on engine after having done the wash and had some over spray to clean up. Minor mistake. Great results, though.
That happens to me sometimes except it’s usually with the doorjambs. I’ll be done with the wash & dry then suddenly remember that I wanted to do the doorjambs 1st because they required using the hose nozzle.
I’m like damn why didn’t I remember?! Lol
what's that?Just read about it on the long river place.
This gets great reviews. I didn't realize they also have a coating too. The Motorplast is apparently excellent and offers high temperature protection and anti-corrosive properties.
Adam's Graphene VRT also looks good.
I used it this summer on a few vehicles, I really really like it. So easy and looks great! Also holds up a long time, months later still looks good.
Nice, I was curious if you ended up using it. Do you think it holds up better than a normal detailer/plastic protection type product? I watched a few reviews and all were impressed with it. It can handle temps up to 250C.
I've tried many products in the engine bay (303, LSP's, Hyper Dressing, Sonus Motorkote) in the engine but the thing is, the engine is going to get dirty regardless and you still have to wash it down again.
