have you tested psi on a 2.5 nozzle? after watching all those videos that matt at og made i assume you want around 1000 psi to wash a car so 900 sounds good.
We where discussion Calendyrs PW. He has the 2.5 orifice oem. I have so I can setting the pressure from my spray gun handle on the Kärcher K7 Full Control Premium Flex with the specs 2600psi 2.6gpm and it's on 240v electric outlet. So I can go very low and up to 2250psi which is the workload rated psi. Cause some don't put the workload psi on the PW you have but only the peak psi recommended that the PW can handle. And that is often the electric motor that is the bottleneck on electric PW.
I know Matt is recommending the 1000psi. IMO with 1000psi and the 40 angle nozzle tip you don't get a good cleaning ability from the PW. The pressure is too low and the width is too large. And you will be working more closely to the paint with such of setup. With a 2.0gpm with that setup you get a PW to rinse off the car soap after the wash. But if you where to clean the car with the water pressure from the PW you would have a 25 angle nozzle tip or smaller and a psi at least over 1500psi. To get a good cleaning ability from the PW. And that's for me important before I wash the car and mostly when cleaning the prewash foam off the car. To get the paint as clean as possible before touching it. The rinse bucket is almost clean after a wash when I'm done. With the smaller specs PW I had before I got a dirtier water in the rinse bucket. So it's very different what kind of environment you live in and how long between the washes you have.
With a higher psi and smaller width of the nozzle tip you hold the nozzle tip farther away from the paint. And still gets a better cleaning ability. If you do as he do and hold your hand about 3-4 feet away from the PW nozzle tip and move it closer until you feel it's hurting your skin. There you have the distance to be safe to not damage the paint. And then it takes a lot of pressure and flow on a 15-40 angle nozzle tip to damage the paint. It's more sensitive to when the paint is already damage and where the trim is attached and the water cooler radiator when spraying into the front grill. But to be on the safe side it's a great measure to do the hand test infront of the nozzle tip. When you clean inside of the wheels and wheel wells with a snub-gun a 1000psi and the 40angle nozzle tip is great as you have the nozzle tip so close when doing that. And to have the water flow to rinse off the car soap after the washing it's also good. But if I put the 40 angle nozzle tip with the 3.0 orifice on my PW when rinsing it off. I could hold the nozzle tip farther away from the paint and get a wider spread of the water and the same effective rinse but faster as I cover more surface.
Have Matt at OG mentioned why the 1000psi is the sweet for him?
