For those that have added QD's on your pressure washer hose, did you use 3/8" or 1/4" QD's? I see both on here and was wondering if there was a reason to choose one over the other.
I plan on running the Apache hose (Apache 10085585 1/4" x 50' 3100 PSI Xtreme Flex Pressure Washer Hose with Female Metric Fittings: Amazon.com: Industrial & Scientific)
TIA!
3/8" Quick Connect Fittings, then again i use a 3/8" pressure wash hose.
I also got rid of all the M22 connections on my pressure washer so no need for M22 hose any more.
I converted from M22 to 3/8" Quick Connect at the pressure washer so I can use standard hose without the M22 fittings and then just use 3/8" quick connects everywhere else.
If you have the money upgrade to stainless fittings as brass fittings start to corrode over time.
You use a 3/8" pressure washer hose on your spx3000? Aren't you severely reducing your pressure?
Well my cheap hose finally developed a bubble - so I took the opportunity to upgrade.... EVERYTHING from the PW out.....
I just got of the phone with the folks at MTM.... What great customer service - they acknowledged Sun Joe is odd with their M22 sizing - and they are almost ready to supply an adapter - they are actually sending me over a test version to connect the the new hose to the PW and if it works they think they'll be able to make adapters available to the public starting in Oct sometime.:dblthumb2:
I not only went with an new MTM Hose (50 ft) - but new Gun with built in Swivel as well as the PF22 Foam Cannon to replace my Amazon cheapo....
I have to admit there was quite a bit of yelling on my part over the last year without a swivel on my hose either.... So really excited for all the new parts.
Please post pics of your setup when you get it all together
very nice setup!I've FAILED on pics so far.... Although I have used it a little since receiving partsrops:
Here's what I did for parts:
MTM Hydro Magnum 28 Foam Kit = SGS28 Gun with built in Swivel & PF22 Foam Cannon
MTM KobraJet 50' Hose = 4,000 PSI 3/8" with upgraded Quick Connects
18" Lance Extension
1/4" Steel FPT Plug
1/4" Steel FPT Quick Connect Coupler
Nozzle Set - 2.0 Orifice Size
Specialized Sun Joe M22/Quick Connect Coupler - Call MTM for part - but looks similar to linked part # - Could also try Amazon Parts linked in post above
Ultimately I am am quite happy with the parts though = excellent foaming from Foam Gun and pressure from washer is rock steady now + it seems to be happier and not re-pressurize when on but not spraying.... Again might seem expensive - but certainly worth while upgradesIm the MAN:righton:
