Lasthope05
- Aug 29, 2007
- 1,113
- Thread starter
- #41
I was traveling all last week for a special project and when working with Operation Comfort and saw this thread but haven't carved out the time to reply till just now...
First, anyone that's been reading my posts since 1994 knows I always say,
"Find something that you like and use it often"
This just means, exactly what it says, so if you find adding mineral oil to your pad when using M105 then that's your business and your "system".
With that said, since starting to post how-to information to the "Internet" starting in 1994 my normal reply to any thread where people are mixing chemicals and product trying to reach a desired end-result, to follow the manufactures directions.
If the manufacture recommends adding something to the product then by all means follow their directions, if they don't then it could be there's a reason for this.
So I've sent the link to this thread to Mike Pennington, the Director of Training at Meguiar's and also to Jason Rose, the Product Manager for the Professional Line just so that they are aware of this new idea being posted as a way to improve M105 and/or Ultimate Compound.
I'm not a big fan of people mixing chemicals because in most cases it can alter the performance of a product in a negative way. That may or may not be the case in this example, I don't know, that's why I've forwarded the link to this thread to people with the ability to talk to the chemist that created the formula.
It is safe to say that at this time this is not an official recommendation from Meguiar's.
I understand what you are saying Mike. I too am one that like to follow the manufactuers recommendations but where so many people have the same problems with M105 many people will look for a bandaid solution(KBM w/water or mineral oil) until the issues are address. Perhaps Meguairs already updated the formula and is awaiting its release after sema. :dunno:
Thanks for sharing your discovery Alan. That was a LOT of product you had on the pad there! Have you tried your method with a more conventional amount of polish?
Yea I know. :laughing: Ron said the same thing to me. I accidently applied too much to the pad because my bottle of M105 is going bad on me. It's starting to thin out and become almost watery. I normally dont use that much at all..
As someone who was struggling with M105 I must say I was able to get the results I was looking for with adding the baby oil to my pad before M105. I didnt have any problems with this method except the pad wont last as long as it normally has if I didnt. I did notice when I would wipe there was a haze on some of the panels manly the doors, but Im not sure if it was there before.
Did you do a proper wipe down to remove the residue after polishing? Since you are introducing more lubricating oil to the product you would need to do either a IPA or mineral spirits wipedown to remove any residual oil.
I gave up on M105 a long time ago, I found a better product that doesn't have all the issues of M105. I use that product 99.9% of the time, the other .1% is D151
I havent entirely given up on M105 as I still have other compounds in my arsenal to use that have more cut but less finishing capability. I have always been interested in the old system one polish when I seen the work that Totoland Mach used to produce with it.
