The Dark Knight Rises - Hacked Blk CTS-V Coupe Full Correction & CQuartz Finest
A CTS-V Coupe - we have been wanting to detail one of these for quite a long time now and while we had a couple booked, they always ended up canceling out...but not this time. The owner of this particular V is a well known and respected member of the EcoBoost forum and an all around nut when it comes to cars and speed. Considering his previous car was a Ford Flex....a 600HP Ecoboost...Ford...Flex...I'm sure you can imagine what he had done to an already extremely fast CTS-V.
While we had tried to set up a date to polish his car a couple different times...for one reason or another it never worked out. Then, a few weeks ago off of a whim while i was out with my girlfriend, i decided to swing by the Pavilions in Scottsdale, which holds a car show every Saturday night...and guess who i bumped into!
The owner and i chatted it up for a while...and i noticed right away, even in the not so bright parking lot lights at the Pavilions, that his hood was covered in buffer trails/holograms. While it looked bad in that light, it looked horrible in the sunlight the day he came to drop it off:
Yes, we are talking about some MAJOR holograms here folks! This was not pretty ....at all. The owner actually first booked a date to just have a wash done as he intended to take it out that weekend....and while he was there he was kind enough to take us for a ride. Dani and I both looked at it and thought it kinda had a bat mobile look to it...after taking a ride in a 10 second, #130 mph 1/4 mile car (and soon to be even faster)...we were convinced our bat mobile interpretation was on the mark!
Fast forward to that Monday, the date we had set for the correction and CQuartz Finest coating....first thing was first...and that was to document what we were starting out with....and as you saw above - it aint pretty.
As usual, from a distance, not bad looking at all. And again, as usual, once you put a light on the situation you want to scream...
I'll let that sink in for a minute. Ok...are we ready to continue? Alright...lets move on.
Initial analysis, the hood was JACKED UP! This was of course a very technical and carefully calculated conclusion...and while the hood was covered in buffer trails galore, the damage to the rest of the car was not to be underestimated.
Lots of good ole fashion swirls...
While the whole car of course was covered with them, we noticed the roof in particular was extremely bad...not just by the amount of swirls, but because of how DEEP they were.
There were some good scuffs in this paint, no doubt about it. After our walk around was complete we got it cleaned up and then got to work decontaminating the paint.
The Carpro Polyshave towel sold by Carpro-Us.com is an awesome tool. Priced well...works great and really makes quick work of bonded contaminates.
While prepping the paint...we came across a few very unfortunate things...such as the lip at the top of the hood. We had hoped it was just caked on compound that was not removed by whoever buffed the paint before...but this was an edge burn. Buff paint at too high of a speed with a rotary/high speed buffer and don't know what you are doing and you can expect this to happen.
Here i am decontaminating the roof.
We did find some other evidence of a bad buff job.....here is some left over compound on the under side of the rear clip
Cool exhaust huh?
Not so cool caked on compound residue.
Here is Dani working the front clip.
After the prep was done...next up was the test spot...the must do if you are going to be effective at getting the paint "dialed in" correctly....this is where we figure out what combo of machine, pad, polish(es) and technique works appropriately for this particular car. It should be noted that the hood and front quarter panels were repainted. We believe the front and rear clip were as well but, being that they were plastic we could not get a paint thickness reading on them.
Whats this mean? It essentially means we are dealing with 2 different types of paint here...OEM...and the repainted sections. This means as we travel panel to panel, we may actually end up having to use two different methods to get the paint perfect. Sometimes you get lucky and what start out with works on the whole car...other times you get areas that really make you earn your pay - as you have to troubleshoot the area and figure out why you aren't getting rid of the swirls...or why the paint isn't finishing down perfectly...and on black...this is always an adventure.
Side note: This is being done in June in Arizona. The outside temp was 110 degrees. To say this has an effect on how the polishes/pads/chemicals work compared to #"normal" conditions, is an understatement.
Onward to the test spot!
Meguiars, meguiars, meguiars. Meguiars microfiber pads, compound (M100 in this case) and polish, used as a compound (M205) was what we found to work. For part of the car, M205 on a MF cutting disc was knocking out everything, but then we got to some panels that had some very deep RIDS left (M205 still got 85% correction or so, but we wanted more) so we brought out the M100.
M100 has been a big plus for us in the heat. While M105 is still awesome stuff...when using a DA polisher...in 100+ degree weather...you have a very short buff cycle. M100 on the other hand gives us a longer buffing cycles with virtually no loss in cut and makes for easy residue removal after finishing a section. This is a big help for us.
Once we knew what to use to cut, Dani grabbed the other Rupes 21 and started rockin' out on the paint as well.
Now of course you're all wondering....hows the paint coming out! Well first lets check out the sides.
This is what we started with:
Got some nice swirls going on there as you can see.
This is what we were ending up with after compounding:
A bit closer, this was before - which you can see here the deeper swirls i was talking about...
And after:
Now for those of you with keen eyes, you can make out the very faint "tick" marks left over from compounding. #So while yes, the swirls were gone, this paint was far from being complete. This is why further refinement and polishing of the paint will be necessary.
After polishing, you can see that absolute clarity and gloss is now visible. If you look closely towards the left side of the reflection, you can still see the slight "grey" look to the compounded, but not yet polished portion of the paint.
All in all...the car was coming along nicely. It was taking a lot of work (and a whole lot of sweat!) but we were winning. We took the liberty of taping off half of that horribly hologram covered hood...compounding and polishing half of it and then pulling it back into the sun the next day at the same exact time as we had the previous day (to get the sun at the same angle). The difference was crazy...
"OBVIOUSLY!"...this was what i was saying in the background when Dani was shooting a short video showing the difference in the paint...OBVIOUSLY we had not done the left side...and OBVIOUSLY we had completed the right :)
Check out that paint. Polished to a perfect gloss with HD Polish...the awesome carbon fiber paint pattern was now looking the way it should....amazing, at least on half of the hood hehe.
Conclusion...the owner was going to be ecstatic!
There was still more work to be done...and the roof, as noted earlier, was going to take a different approach to get into the condition that we wanted it. Enter Meguiars 3000 grit finishing discs....
It was time for a little damp sanding on the roof. While we could compound away over and over and over on the roof to remove the deep defects that were present, the quicker...and actually "less invasive" method (meaning that this is actually safer and will remove less clear coat) was to damp sand the roof with 3000 grit...then compound and polish.
The good ole Porter Cable 7424. Our first machine we bought years ago...and still even today its being used...never had an issue with it even once...just a great machine. Here it is being used to #sand the roof.
From this step it left a uniform haze on the paint. The key word being UNIFORM. So rather than having defects ranging from a 1-10 in terms of depth, they were all at the same level now...which meant we should fairly easily be able to compound them out. While the combo of pad/compound/machine was working to remove the defects, it was taking a bit longer than i would have liked. So, i broke out the rotary and Megs Wool pad...along with M100 and was able to very quickly remove the defects on the roof.
I then followed up with the Megs M100/MF disc combo we had been using, to further refine the defects...and then polished with HD polish. Now, while this SOUNDS like it would take longer to do since I added in a couple of steps, in the end it actually saves time and gives a better result.
This is an idea as to how our roof looked after sanding.
Note its uniform. Next up would be the rotary and wool pad combo...
After that combo this is how the finish looked. Yup, there are buffer trails, but i dont care about buffer trails after wool and rotary. Really, its sort of expected....but since i'll be further refining the paint - all was good.
Dani in the mean time was doing some edge/tight area work...such as the side mirror here.
And the fun part, under the rear clip which was NOT easy to get to...
Let me take a moment to give a quick shout out to Mr Kevin Brown (again) of BuffDaddy.com ....because while using the Rupes 75 (seen above) early on in the detail, it suddenly froze up. It would not rotate or oscillate. After a quick text/call to Kevin, he actually sent a diagram of the inner parts of the Rupes...explained what had likely happened (a piece of rust go stuck), advised me to spray it liberally with WD40 and work the counter weight by hand to bust the rust free...and that all should be good (all this happened at the end of day 1).
The beginning of day 2 i went out and did as he had advised...and as you can see above..it worked like a charm...which thrilled Dani because, to use her words "I gotta have my lil' Rupes!"
Speaking of the end of day one....between having several polishers, lights, lil fans, air compressor line and cords..with more cords and a side of cords...well...this pic had to be taken...
Dani described it as "Bufferville USA". She also described it as a freaking mess that was driving her crazy! Since having OCD is a must to be a good detailer lol, seeing THIS really whacks you out with the quickness! You have to stop and untangle this mess because you #know if you don't you will just set a match to the whole thing because looking at it is going to drive you crazy!
Ok, back to the detail. Day two we finished up what little compounding we had left and were to start our final polish. We did manage to snag a couple more 50/50 shots....
Lookin' good, lookin' gooooood!
Dani working a couple left over tight areas...bringin' out that shine like a champ.
Tail lights were done as well, as you can see they were swirled up nicely (bottom) but were coming out nice and clear after we worked em'.
One thing any detailer can tell you is, after a long compounding session there is going to be compound dust ALL OVER (as im sure you could see in previous pics above). So it was time to re-wash the car...this time we would be doing the tires and wheels as well (we didnt do them initially since we knew a re-wash was going to need to be done - no sense in doing them twice!)
Iron X Snow Soap is a great prep wash soap...in this case it really worked well to help break down any left over any compound residue and compound specs...the other sweet part that i really like is how it rinses away. It leaves no soap residue behind which is great because at this point we dont want to have to touch/wipe the paint any more than necessary.
We were then able to blow dry the majority of the water from the car (thank goodness for spotless water!) and then pull it back in for our final polish.
The final polish was taking the hazed look left after compounding...
And making it nice and clear after polishing.
After final polishing, we did notice a few deep scratches left behind that were missed...so...we broke out our new little 2" polisher to spot compound these little suckers.
Dani began working on the batmobile wheels, cleaning them with Eraser and then coating them with CQuartz Finest and dressing the tires and wheel wells with Carpro's PERL
Pretty!
Finally, the polishing was done...the paint was perfect and it was time for us to do a wipe down with Eraser to insure all polishing oils were removed and the paint was "naked"
Our softest Crazy Pile microfiber towel is used for this step...since we do not want to induce ANY towel marring.
Gotta say, thats a pretty awesome picture right there!
And then, it was time....the black bottle for the black paint. Break out the CQuartz Finest for the glossiest, deepest looking finish...add in the fact that it comes with a 2 year warranty and offers seriously hardcore protection...and you have a winner all the way around.
Applying the first coat...
First coat is curing...
And then a second coat. Like Raisin Brand gives you two scoops, we give you two coats!
Dani doing the same...while using her infamous "butt pad" lol. Hey, it does work when doing very low areas!
Round n' round we went, coating everything...paint, headlights, tail lights...wheels were already done. Then it was time to wipe down the door, trunk and hood jambs, do the glass...and pull this black shiny sucker outside to try to capture all of its awesomeness.
Lets do it...
Oh yes...it was black...The Black Knight Rises!
How'd she look in the sun you ask??
I don't care who you are...thats one sick looking ride.
No swirls means more clarity, more clarity means more gloss, more gloss means your ride has been done right.
That roof that was so badly swirled...that we sanded down...came out gorgeous.
The hood as we already know...was once again looking how it should (but now on both sides haha!)
Glass status....
If it looks like it's snarling at you, its because it is...
Front clip looked as good as anything else...
The bat wheels looked awesome
This thing had more suns reflecting off of it than we could count.
The previously swirl covered trunk looked perfect...
And of course...the reflections were like looking into another dimension. As our neighbor put it "The paint looked like if you touched it, it would send ripples throughout it..."
I'd have to agree...yes....yes we have potentially ripply paint.
You know that commercial that says "We don't just build cars, we build Cadillacs"....i think this car would have been a damn good contender for being in that commercial :)
And of course, no write-up of mine would be complete without finished photos under...."The Tree"...these pictures deserve to go into the gloss hall of fame in my opinion....
Holy glossy paint batman! (To continue with the batmobile theme lol)
This is the roof....seriously...it's the roof
If it wasn't for the fact that the tree is upside down, it would be easy to call me a liar lol
The story ended with one very happy owner, and one extremely glossy Dark Knight :). It was great to finally get one of these under our belts. While, as usual, it was no cake walk...it was still a huge success and hopefully we will have more of these come our way. The owner was so pleased with the outcome that he has willingly broadcasted his excitement to other CTS-V owners in our area, so hopefully there will be more to come.
As always, thank you all for reading/looking...i hope you enjoyed it. Take care.
That was an incredible transformation. Those Unigrit discs are wonderful for leveling out deep scratches and really leave you an even surface to polish back to gloss. I've been using the same 2 inch orbital sander/polisher as well and it's been great so far. I had to measure and cut my own 2 inch polishing pads and even cut out a foam interface pad for sanding with 2 inch discs. May I ask what pads you were using or did you have to make your own? You guys did an excellent job, keep up the good work.
you both killed it again, bravo to both you and dani. i bet the owner was absolutely thrilled! props for one of the longest write-ups with pics too... ;)
Man (and Woman), you raised the bar way too high now. One word came to my mind in recurrence more than others while reading your awesome write-up, so I'll resume my comments:
PERFECT.
PERFECT.
as mentioned earlier in his write-up (kevin's website), has the 2" foam and microfiber pads...
Lol sorry for being my usual long winded self, but it was a lot of stuff to cram into a write up! Thank you though and glad you enjoyed it :)
I agree, they are great discs - very nice to work with. And yeah i liked that little harbor freight polisher, for this instance i just cut some out of an older 6" mf pad...but i do plan to order some from Kevin Brown at Buffdaddy.com ....he has the exact fit ones...along with assorted foam ones to choose from :)
PERFECT.
PERFECT.
Lol, dont really believe perfect is possible since im far from it myself...but its what we strive to get as close to as possible :) Thank you for the kind words and really glad you enjoyed the write up.
Amazing job as usual on the car and the write-up. A lot of great information shared. You guys do some excellent work and make a great team. Thanks for sharing :dblthumb2:.
Exhaustive write up and I read the whole thing!, Very nice work, Dark Knight indeed.
HUMP
Holy crap, you 2 seriously do some of the best work I've ever seen, your write ups always leave me speechless.
You can actually tell the hood is carbon fiber now that all it's free of all those holograms.
Amazing job !!! I am sure the owner was speechless...
Amazing transformation and a fantastic job and write-up. Holy deep reflections batman!
Hi Wills and Dani...
An Idiomatic-Comparison:
•Just as this CTS-V reflects an evolution of the
Art & Science design, that has come to define Cadillac...
-So has the evolution of yours and Dani's Art & Science design---(through use of the most modern products, tools, and techniques)---that has become synonymous with the definition of: Ultimate Detailing!
Once again:
-Congratulations on the dedication and hard work that you guys have imputed to grow your Business into one of the more elite detailing-centers.
Note:
•Surely you've heard of "The Wolfgang Four"...
-I propose the inclusion of you two into the Detailing World's category of best paint correction specialists:
"The Defect-Diremption Duo"!!
Wow. What a fantastic job.
Never have I felt like such an amateur!
Sent via mobile device.
Great job! I think I saw this bad boy driving around a few weeks back, those rims seem awfully familiar.
Thanks Frank! We've developed quite a synergy over the years in detailing and basically anything else we do together...its cool being able to work with my sis and tackle some pretty crazy jobs :)
HUMP
Lol hope it didnt wear you out too much, but thanks for taking the time to read it! :dblthumb2:
Lol yeah before hand it just looked like crazy smearing all over the hood. They actually PAINTED that pattern onto the hood so it looks like CF...i too thought it was legit CF, but the owner corrected me :). The sides of the hood were actually still plain black which i THINK you could see in a couple of pics. Thanks for checking it out :)
He was pretty happy thats for sure, he posted about it all over facebook...hopefully it'll turn into a few jobs for us :dblthumb2:
Hahaha, holy deep reflections for real!
Once again:
Note:
Hey Bob! Thanks for checking it out (as always!). This one was quite a sweet turn around...it looked beautiful in person. I dont know if we should be classified as up there with the best...but we are working on being qualified :) Hope to have a shop in the next year to work out of...i think a lot of things will get even better from there on if all works out...just a big jump...but i think its close to being time.
Stunning work on what looks like a rocket!
Seriously it was a rocket, i shoulda grabbed a pic of under the hood...it was sweet looking...and the start up was just...wow.
Lol thanks Kevin...trust me i see guys post on facebook a lot with work they did and i too feel like a total newbie...but ya gotta keep pushing the envelope to get better...and thats what we try to do.
Car looks beautiful! Great job!
Thank you so much :props:
You may have..i think he usually takes it out on the weekends....especially to the track (no surprise there huh?) He'll also hit the pavilions here n' there too. Should be very easy to recognize now lol.
