Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
- Thread starter
- #81
Thanks for the quick reply. Wow!
I'd say its 80% daily drivers and 20% show cars.
I'd say that's a pretty normal ratio for most detailers.
I've recently teamed up with a local automotive restorer so I expect the ratios to change slightly. I have a few years experience all on the PC and I'd like to think I have good technique. (Will post an intro with pics of my work). Hope that's enough info. Based on that criteria what would you purchase?
Thanks
Eric
Since you already have a polisher with a free spinning drive mechanism, I'd lean towards the Flex 3401 which is forced rotation, forced oscillation.
You cannot stop the pad on a Flex 3401 from rotating. Can't be done. This means no matter what the shape of the body panel, if you're doing correction work or polishing work, two steps that abrade the paint to make it look nicer, then the tool is working.
Anytime a pad stops rotating or rotating enough to not abrade the paint then no work is being done.
The above is just an observation about the differences between the Flex 3401 and ANY tool that has a free rotating drive action.
That said, the best way to figure out which tool you're going to like is to test them all out by buffing on real cars. You get to do this at all my detailing boot camp classes.
If you like, I can post picture after picture showing my students using all the tools, that's easy enough to do. Here's a few pictures from a recent boot camp class of the tools everyone used...
My next Detailing Boot Camp Class is at the end of September. This class always fills up fast and you'll get a chance to use all the popular tools on the marked, a wide variety of product lines and you'll also get to learn how to wetsand by machine.
The link to sign-up is at the top of every page, just click on the graphic at the top of each page or click on the graphic below.
