Do u find a major difference in cutting power between the 15 and 21?Awesome write up Mike!!
Kind regards
Paul Dalton
Miracle Detail
What negative things have you heard?
Couldn't agree more. I'm not questioning whether the Rupes is a quality machine, I'm just asking how many demos has the AG Staff done with every polish from every manufacturer with every combination of machine and pad? Look at the results, it's all good. It's more about technique then equipment.Neg:
Limited power and backing pads
Proprietary pads, polishes
Pos:
Big throw
Strongest pure DA available
IMO it seems to be a quality polisher. Being pretty new there are going to be believers and non believers. In the right hands all of the better known polishers will do what they need too.
Neg:
Exactly!!!!Limited power is not a negative. The 21E stroke is almost 3 times of a normal DA, including the Flex at 8mm. This results in the pad cutting so much with each orbit that it doesn't require that heavy pressure like a PCXP or need to be force driven like a rotary/Flex. Keep in mind having such a large surface coverage, doesn't always make it ideal for panels with big dips or bulges. I'll still pull out my GG6 to get in those areas. Hear it from one of the best in the industry, Kevin Brown, just Google "Rupes LHR 21ES Random Orbital Polisher - Features & Benefits."
The machine works great with other pads like Megs MF. You don't have to use only Rupes pads to get the best results. I also use my 21E with the 15E 5" backing plate. I have not used the Rupes polishes yet. Haven't really needed to try them out yet when I'm getting 1 step corrections done with Megs MF Finishing + M205 or bumping it up to M100/M105 for more cut.
Rupes > 3401
I've tried both.
I knew you would like it! Any word on how well the chemicals work?
I've already tested the entire system on my demo panels with Gionata the Business Development Director here at Autogeek. One thing I like about the paint system on my demo panels is they show anything and everything.
If a "system" works... I'll know it really fast.
If a system doesn't work... I'll know it really fast.
Are the polishes DAT or SMAT?
Dang a RR as a test case, nice ride. I need to hook up with you Mike I like the way you roll!
Crazy Amos said:No washer mod ???
What backing plates are available for the Rupes?
Kind regards
Paul Dalton
Miracle Detail
NIIIIICE machine!
It looks pretty easy to lift, carry and light to work with.
What about the pads, are they different to the LC flat pads?
I would love to try one of those.
So sad that I couldn't try it at the detailing class I attended.
Do they come in 220-240volts? If the do, that would be great news for me.
Mike, I hope you enjoy my recommendation on that Rolls Royce Phantom Drophead, my customer is very excited that you are working and using the latest products on his car.rops:
Neg:
Pos:
Big throw
Mark,
When you get tired of your Rupes, I'll buy it... :buffing:
I've already tested the entire system on my demo panels with Gionata the Business Development Director here at Autogeek. One thing I like about the paint system on my demo panels is they show anything and everything. If a "system" works... I'll know it really fast. If a system doesn't work... I'll know it really fast.
I'm happy to say the system works so well I trust in the above Rolls-Royce
Have to go, it's 5:00pm Thursday and I have cars in the AG Garage to go play with...
Again, there may be no NEED, but there's nothing negative about it, and it does help! I trust KB.No sir.
Rupes, Autogeek and I don’t recommend it. I spoke with both Marco and Gionata about this issue at length and they explained exactly why they designed the tool they way they did and that there is no need to modify the tool.
RUPES has clearly stated that using the 5" backing plate with the 21mm will not void the warranty. That's a pretty telling statement if you ask me. Sure, it makes sense for them not to recommend it, but it will work just fine. Again, I trust KB.Rupes recommends using the correct and matching backing plate engineered to be used with the matching and correct tool.
For the Rupes LHR 15ES you want to use the,
Rupes LHR 15EX 5” Backing Plate
For the Rupes LHR 21ES you want to use the,
Rupes LHR 21ES 6” backing Plate
Rupes > 3401
I've tried both.
Neg:
Pos:
Big throw
I'm curious about this myself. I asked this question of the RUPES reps at MobilTech. They said that their abrassives technology is proprietary technology. I got the impression they really did not know or understand the question. Anyone here know if they are smat or dat?Are the polishes DAT or SMAT?
Their tech department informed me they're a combination of SMAT and DAT(each polish).I'm curious about this myself. I asked this question of the RUPES reps at MobilTech. They said that their abrassives technology is proprietary technology. I got the impression they really did not know or understand the question. Anyone here know if they are smat or dat?
