PA DETAILER
- Mar 5, 2011
- 6,017
- 251
I have a good backstock of Duragloss #253. Always buy a few during a 25% off sale. After trying the TW on a whim, it may become my main tire dressing. It is that good.
For those cleaning their tires with Tarminator, does this product foam up at all? I'm guessing the procedure would be to spray, scrub, and rinse, correct?
Also, how would using Tarminator compare to using something like SuperClean straight out of the bottle?
On the cleaning side of things. I would give the TWHS Tire prep cleaner a look. It is perfect for a prep before their tire dressing or any other dressing. Gets the tires surgically clean!
Hybrid Solutions Hyper Foam Wheel Cleaner & Tire Prep
On routine tire cleanings I use 3D YELLOW DEGREASER.
3D Yellow Degreaser 106 128 oz.
Agreed with maybe tires not clean enough. I would recommend getting a drill brush. Available on the big A and Autogeek.
Works way better than hand scrubbing with a TufShine brush.
Also product seems to be 4-5 years old. Do they see frigid winters? All those factors could lead to product being bad.
The TW Hybrid acrylic is a solid product. One of my favorites is Tac Ststem tire coating. If you look at like a stout dressing instead of a coating it is a great product. Got a solid month from it.
I’ve been using some mixed 50/50 with Perl. Not quite as durable but looks great.
I've got a Yellow drill brush I got for carpets, but I think it's to stiff for carpet, so maybe I'll switch it to wheel duty.
These are all <3 yrs old (3 for the VRP, less then 1.5 for the Griots.) The products have never been frozen, they see cool temps about 45*F but never frozen.
I picked up a bottle of the foaming tire cleaner today….wow! I wouldn’t use it for maintenance washes but for stripping anything on the tire….heck yea!
I also picked up a bottle of the Graphene tire coating too, worked pretty well, I’ll know in the morning if I really like it but so far it’s looking very good! This is after two coats, I added a third this evening!!
JF
Tarminator is an effective tire cleaner or 303 Tire and Rubber has been strongly recommended too. Tuf Shine is another very good tire cleaner though you would only periodically need to clean tires that well but it may be worth a shot with what you’re describing.
Duragloss 253 is a well regarded dressing that I use with a flag-tipped brush though I need to find a smaller flagged-tip brush since my tires are lower profile.
Use a variable drill to prevent splattering.Well, I delegated my yellow drill brush to tire cleaning and tried both Simple Green 6:1 and SuperClean and made a huge mess (mostly on me!) but did little to the tires, lol... Is there a trick to using a drill brush without making such a mess?! Maybe a smaller one?! Don't think I'll use it again for tires as just to messy, and stick with my stiff tire brush I don't use often enoughI scrubbed with drill brush for at least 4-5min/tire and pressure washed it off. So there is definitely a layering on it that's making it not dry it seems like, even after all this scrubbing with the two different cleaners, I could still wipe dark off with my finger, so it needs more cleaning for sure...
I'll have to pick up some Tarminator I guess and try that out, or maybe the TW Hybrid Solutions Foam cleaner...
I don't want to spend a fortune on tire stuff, as some of these are just not worth it (no offense!) I rather coat them once a month and spend less, then once every few months+ and spend 3-4x more. I've not coated them again for now till I get the rubber cleaner...
PS: I've had the yellow drill brush and a couple other brushes soaking in Simple Green and Dawn for a week now and the black slime just won't come offGuess I ruined this drill brush...
I did, still made a mess. :/
I've washed the car a couple times now and still not put anything on the tires again yet...
I need to pick up something better then the Simple Green and SuperClean I have, just not got around to it yet![]()
Still can't get the brushes I used clean either, this is getting annoying![]()
Get some LA’s Totally Awesome and use it full strength. Spray your brush and get it nice and soaked then scrub it against your driveway, give it a good rinse and your brush will come clean. Guaranteed.
