Turtle Wax Seal and Shine
Why is TWSS beading up more
Apex mentioned PTFE was a small amount in the SNS. That's useally have a high contact angle. Could be that the mix they use have a high contact angle. Will see if I can get a picture on the white paint I applyied it on. But didn't seem to be that extreme on it that I applyied it on. And that's about the lack of prep I did I think.
To me it looks like this was recently driven and the coating side sheeted off most beads while the SNS side has most beads remaining.
Good looking beads either way.
I think I would use this product as a stand alone. Wash, decontaminate, paint cleaner/finishing polish, spray this on. Then add another layer once a month after a wash. Easy as a spray wax, should make keeping your car protected ridiculously easy. Once or twice a year you decontaminate and clean the paint. What is not to love??
Winner winner chicken dinner.
Sent from my SM-N950U using Tapatalk
Is the older version of Turtle Wax Seal and Shine the blue bottle TW Spray Wax? I was told that the black bottle Seal and Shine is a new formulation.
Concours Nova Jet. I bought some from Australia and had it sent to me along with Concours Nova Lustre. The Lustre is wonderful and I'm just a few weeks into what I hope is an endurance test vs. PNS. It goes on just as easy as Bead Maker and claims many months of protection. I applied Jet on a different panel (and, on a 3rd panel, Jet over Lustre) and didn't enjoy it. It's really hard to wipe off. I'm still finding streaky patches weeks later. Jet did really well in some comparisons but in my situation I didn't like it.
Applied a 2nd coat, such a unique product
What’s unique about it?
Well, when you spray it on the panel the consistency isn't very watery like you might expect, that's first. Next is when you wipe it in, it spreads and you have to work it, again, not some watered down product like you might expect and finally the final buff is SO EASY. Usually a similar product has one of these 3 features, all 3 are found here with TWSS
Just bought the new TW Ice snow foam soap, can't wait to get it. I'm going to try 2 ounces in my IK Foam 9 and see how that works for starters
We got some more rain today. And when I looked into this thread I remembered that I was going to take some beading pictures LOL. It has just cleared up from the rain this evening in Sweden.
Turtle Wax ICE Seal N Shine it seems like I was able to buff it off good. It's hard to see on a white paint slight smearing. And an acceptable beading I think. Not the most extreme I have seen and not the worse either. And is confident on a better preped paint I would get better results from the water behavior. Will try to put on another layer when able to. What I did notice on this car that has some deeper swirls that needs compounding I think. Is that it filled the finer swirls pretty great actually. It was clearly in the sun that it was the deeper ones that showed. So another plus for SNS in my book. Will be fun to see what an extra layer of it in better conditions can get me.
Some beading pictures and remember it can be some residue left that may excell the beading after the next wash.
attachment.php
attachment.php
The rest of the car got Gyeon Wet Coat on it. And this new version really gets the water behavior up to high performance. I have used it before on this car and it needed at least 2 applications to get to this level. So I at least noticed a bump up in strenght from it. And I think that it's like SNS that on a swirled up paint it takes a couple of applications to get the paint smooth enough to get a high water contact angle. Compared to TW SNS I think that Gyeon Wet Coat is glossier and more hydrophobic. But SNS filling ability is better and a little more glow from it vs the Wet Coat crispy and sharper looks you get from it. Think that I may like SNS looks better on my silver metallic paint as Wet Coats look is hard to beat on white paint IMO. When useing the Wet Coat on the silver metallic paint the sun almost flushes out the sharp crispy look from it. And that's why I like a more carnuaba glow look on my silver metallic paint.
Gyeon Wet Coat in action. Application 2 sprays on a wet panel and spread it out with a mf applicator sponge and PW rinsed off thoroughly so the water pressure makes it to bond as good as possible. I like the water behavior a lot from only 1 application of the new version of Gyeon Wet Coat. So if you like a high sharp crispy look and a very good water behavior. Get you some Gyeon Wet Coat and see how you like it.
attachment.php
Also as plus from both products the plastic trim needed to be protected and looking a little dull but these took care of it. A little nod to TW SNS in this comparison on the plastic trim.
/ Tony
I was getting ready to pull the trigger on Jet until I read this.
While the chemical repellencie is unreal, I wonder about longevity and physical abrasion/or erosion. Waxmode's video at 5 months was somewhat telling on that area.
Meh for a spray on product physical abrasion resistance isn’t gonna be high. In fact almost no product lasts with physical abrasion. I take a car with SNS on it through a soft brush car wash and it’s held up so far better than most. I’m continuing to monitor it. With no rain probably take it through again Friday. If we get a shower and it gets dirty I’ll take it through sooner
It’s likely a 3 month product with autogeek style bucket washing. Some will get more some less. I don’t know how anyone would have a problem applying this again each 3 months give or take.
The price has been outstanding on and off and the protection has been good for as long as it’s been around
Rained tonight: beading shots
TWSNS:
PA COSMIC
Old shots HS recharge v2
Close on all 3 but I feel HS recharge had tightest most uniformed beads. Still impresses me the TW and PA are on a prepped hood, recharge was not. As for beading off the car Cosmic is near coating like.
PA says if used with primer spritz cosmic spritz will last 12-14 months.
TWSNS:
PA COSMIC
Is the HS Recharge picture old, or is the picture current on HS Recharge applied long ago?
The hydrosilex was from winter. Bout 4months old I believe when pick took. No prep at all to hood. No Lsp as far as I could tell. 1st thing I applied to car and it’s what got me back into this hobby...
