I use to. LOL But I find that stereotype odd. I usually find that people driving crappier cars drive worse. Prius, Camry, mini vans, leafs, etc.
LOL I am going to have to stick to my guns here and say that in most freeway situations, my blinker does you no good. For one thing I am going faster than you. The second thing is I am paying attention to more than what's right in front of me.
I can without a doubt swear on my Rupes life that if you and I were on the same road together my driving would have zero affect on you. And even better, if you made a mistake and cut into my lane a little close to me but going faster, I wouldn't care at all. As long as you don't make me hit the brakes you can do whatever you want around me.rops:
Here's a question for you gear heads. The original post what grinds your gears? I'm a pretty good driver but don't know much about maintenance. I once shifted my brother's old prelude without using the clutch. I was only able to do that once. Why is a trucks tranny set up so that I never have to use the clutch except obviously from a stop
The slow drivers (you know who you are Honda-nation)
But back to turn signals.... I'd rather have someone use their signal, then pull in front of me and cause me to hit the brakes, then to just pull in front of me. At least I had some warning that they were coming over, even if they shouldn't have.
Sloppy synchronization or worn gears. You can shift a stick without engaging the clutch if everything is spinning at the perfect speed and things (gears) mesh/engage perfectly.
If everything is sort of worn, or its a truck (higher tolerances compared to sports car) it becomes easier to find this sweet spot.
When transmissions first came about, like a zillion years ago - there was no clutch. It was up to the driver's skill to shift. Then came clutches, and later synchronizers - to make it easier.
Calling me slow?Actually I pretty much go the speed limit whether I'm in a 100 or 500 hp car. Except on the PA and NJ Tpke. Going the speed limit makes you the "20 under" guy.
Once on the PA Tpke I had to deliver a Porsche to a customer and I met her at a rest stop. We came from opposite directions so we were parked on opposite sides. Anyway, on the way back, it was one expensive toll for me because it looked like a made a u-turn. So I guess having to go north to go south grinds my gears.
thats freaking awesome!!Maybe everyone should drive an Infiniti:
Infiniti Q50 Active Lane Control - Selfdriving Car - YouTube
Plastic shopping bags anywhere
thats freaking awesome!!![]()
Just happened to me yesterday, that really burns me!when you hold the door for someone and not a mention of thank you or appreciation. ungrateful people...
Did you notice it was in Germany? Self-driving cars are much closer to reality in western Germany and France than anywhere else for a variety of reasons. First, the level of driver education and testing is much higher than here. Second, road vehicles in general are also kept at a significantly higher standard through required maintenance and inspection (similar to JDM cars). Third, the roads are better engineered, built and maintained overall. Fourth, road marking and signage standards are much more strict.
The Infinti in that clip was just essentially set on cruise control and it used adaptive cruise and lane keeping to "drive" the car; Mercedes was the pioneer in developing and offering these features (as usual) with the 2005 W221 S-class. It used cameras and sensors to "read" road markings and speed limit signs -- the active speed control module is deactivated in non-EU W221s because none of our road and speed limit signs follow a uniform standard.
If you want to see a cool test, and not a foolish and dangerous stunt by an idiot on a public road, check out Mercedes engineers testing an actual, self-driving W222 S-class. They took a stock 2013 car and outfitted it with just a couple of test modules, then gave it a destination 100 km (62 miles) away and let it drive them there.
http://youtu.be/beHOwZRkqOE
Lol, you should drive in Memphis. People waiting to make a left turn before an intersection will often nose themselves out to encourage people to stop and let them through. I'm usually a nice guy and let them out if I was already coming to a stop at the red light, but it drives me batty how 99% of the drivers here don't bother with a wave or any notion of thanks if you let them out!
Speaking of noses:the ones out nose pointed at on coming traffic
