Eldorado2k
- Nov 9, 2015
- 14,583
- 730
- Thread starter
- #41
Ha. I'm about to go outside and try it now. I feel like a kid on Christmas.
I think the Uber has more surfactanta, which means it is slicker, so will roll off easier. Rinseless washes need both encapsulation, and slickness. The Megs products seem to be more encapsulant oriented, and the WG more slickness oriented. Both will probably work fine.
2 16"x16" towels to waterless wash an entire 17' Cadillac.
That is extremely brave of you.
Update: Ok so I just had a chance to re try the Wolfgang Waterless Wash on my car. No more dew or moisture on the vehicle and now it worked fine.
Note to self: Don't ever use this stuff in the early morning when there's dew on the car, or on a wet vehicle, because it'll suck. I can't imagine this being good as a drying aid.
Here's a shot after wiping down half of the hood. I do back and forth wipes similar to washing the car with a mitt and wash bucket. Nothing extraordinarily carefull.
Here's a shot after the entire hood has been cleaned. 2 sides of a towel so far.
Pretty much done with the whole car at this point. 1 towel completely dirty [both sides] and my 2nd towel is basically still clean. All I have left is the drivers door rocker panel and the front bumper, which I'll begin using the 2nd towel for.
And no swirls!
I always give new products a couple tries before saying Yay or nay. Many times you have to adjust to the product and environment to get a good feel and use to it.
Hey Eldo, FWIW, this is THE BEST RW on the market, period!
I use 3 ounces to make my FrankenDetailer and it mixes very well with it too. I actually use 2 ounces per gallon for WW use but 3 ounces plays it safe and that's them, WG, looking out for the people IMO.
If you buy this and you don't like it, send it to me and I'll pay you for it!
Next time you wash your car, hit it with two or three sprays per panel before you dry (waterless ratio). Not only will it amp up the gloss, but it makes the towel slide over the surface much more smoothly. No need to spray precisely. Just randomly shoot it here and there while walking around the vehicle. It's my favorite use for this product.I can see how it might be the best rinseless wash on the market. When I used it in the morning it seemed to want to produce a very wet experience when combined with the damp vehicle. It actually felt like I was doing a rinseless more than a waterless. Things were a bit more like expected them to be when used on a dry surface through. So I think it'll be good.
Btw, what exactly is your Frankendetailer mix?
Wolfgang Uber @3oz. per gallon vs. Megs D115@6:1.
Here's Wolfgang Uber just seconds after being sprayed onto the panel. Notice how much it just beads up and immediately starts dripping away..
Now here's D115 just seconds after spraying onto the panel. Wow what a difference. This is what you call encapsulating.
IIRC, D115 could be diluted as high as 1:20 for high humidity/temp. At this mixture, it would probably exhibits similar characteristics you've experienced with Uber. I haven't gone pass 1:8, so I could be wrong here.
